PorscheGuy79's Avatar
Laptop problems, computer guys help!
Hey guys,
I have a Alienware Laptop computer that I purchased about 3 years ago, it was one of their first laptop models. It had been running like a champ for the past 3 years, with only minor software issues here and there as you would expect from a computer of its age.
Recently, I had left it on for a couple hours when I was at work. the monitor went off as it usually does and I came back about 3 hours later. I found the computer on, the fan running on high (not terribly unusual) and the mouse, keyboard and touch pad all unresponsive. After not having any luck getting it back I did a hard shut down and waited for a good bit before turning it on again. When it started to boot up there were now dozens of small (about the size of a stamp) groupings of horizonal lines (maybe about 5-6 lines per group). This happens across any screen that isn't a DOS prompt, that means the windows boot screen, the Alienware start up screen, and the login screen. The DOS prompt does not have this error (IE the screen where you can select to start it in safe mode). Another thing about it is that when you get to the XP sign in screen the cursor works but my login name and icon are unresponsive. This is true for both a normal boot as well as in safe mode.
I hope that you guys can possibly give me some direction on how I could proceed. Alienware wants me to sign up for an additional warranty to try and fix it but I wanted to get some cheap input first before paying money on something that might be toast.
Thanks in advance.
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 06-17-2006, 01:17 PM
Gon fix it with me hammer
svandamme's Avatar
reinstall the bugger...
if that don't work ... get a new bugger...
Stijn Vandamme
BIMDIESELBMW116D2019
Old 06-17-2006, 01:19 PM
I am some what computer savy but its been ages since I took a class on it. How do I go about reinstalling again? (am I gonna lose everything I got on the comp too?)
Matthew
Old 06-17-2006, 01:28 PM
svandamme's Avatar
in that case... find a geek locally
no way am i gonna remote geek your pc... sorry mate , but it don't work like that to risky
Stijn Vandamme
Old 06-17-2006, 01:32 PM
No biggie, I understand. My mom knows how (sad I know). Im a pretty good Geek, just haven't had much opportunity to practice restore disk procedure.
Matthew
Old 06-17-2006, 04:51 PM
Monkey+Football
Icemaster's Avatar
Send a message via AIM to Icemaster
Try a system restore first just for giggles.
Start - All Programs - Accessories - System Tools
Take it back to a few days ago, you wont lose anything.
<Insert witty comment>
85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff.
Old 06-17-2006, 06:11 PM
Monkey+Football
Icemaster's Avatar
Disregard that...i just re-read you'r post.
So you can't log in at all? Even in Safe mode?
Old 06-17-2006, 06:12 PM
I will try again but as of last time I tried...nope not even in safe mode.
Matthew
Old 06-18-2006, 04:18 AM
Monkey+Football
Icemaster's Avatar
Uh oh...did you receive any system restore CD's when you bought it?
Old 06-18-2006, 05:15 AM
Okay this is gonna sound ridiculous but... I let the computer sit and think about what it had done. I started it up this morning, everything looked fine and then just ask I am typing this message...about at the word "computer" it started putting out all these little boxes again...and they keep multiplying...they are multiple colors...black, green, red, yellow. Ahh I will try and restore now.
Matthew
Old 06-18-2006, 05:53 AM
Irrationally exuberant
ChrisBennet's Avatar
I'm not a computer expert or anything but if it was me, I would pull the hard drive, put it a desktop PC and copy everything off it before doing anything that might make cause me to lose all the data.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-18-2006, 05:55 AM
Monkey+Football
Icemaster's Avatar
Sounds hardware related to me at this point. Video or system board is my guess from this distance, doubt that re-imaging it would cure teh problem. BUT...if you can get to a state where you can drop your most ritical stuff onto a USB thumb drive, I'd do it just for safe measure. If it IS system or video related, your hard-drive most likely will be OK once the failed part is replaced.
Chris, without the right adapters, no way to pull a slimline laptop drive and slap it in a PC. It can be done, but you need the right cables (which I no longer have...).
Old 06-18-2006, 07:01 AM
Formerly bb80sc
Vipergrün's Avatar
My bet is fried video. Have you tried hooking up an external monitor to it? If you need to save the drive, you can get a 2.5" drive USB enclosure. Drop your laptop drive into it and access it via a desktop system.... To troubleshoot further, whether it's video or not, try to download a bootable copy of Knoppix (Linux). You can boot from that and examine your system.
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 06-18-2006, 07:13 AM
