I'm not here.
K. Roman's Avatar
'72 VW Beetle Oil Change howto?
I have a friend who will be traveling to Reno in a couple of days and I wanted to tackle an oil change before she left. Anyone know the process for this car? I've done multiple changes on 911's but never even seen an old VW engine underneath.
Is there a sump plat like on a 911?
Help please!
Keith
"When do we say we can stop the Whole-Sale State-backed discrimination against straight white males? - island911 (This guy is insane, no?)
Old 08-16-2006, 11:47 AM
cantdrv55's Avatar
Maybe they can find the info here?
www.thesamba.com
Old 08-16-2006, 11:50 AM
Purchase a sump kit, which should consist of a set of dump gaskets, copper gaskets for the plug and sump plate nuts, and a screen.
Warm up engine.
Drain oil
Remove sump plate
Clean sump plate
Install sump plate with new screen and gaskets; I use Aviation Permatex on mine
Install drain plug
Add 2.5qts of oil, season to taste
Also:
Remove aircleaner
drain oil
clean crud out of the oil bath
add fresh oil (what you had leftover from the engine oil change)
Re-install air cleaner.
Probably not a bad idea to do a valve adjustment, while you're gettin' dirty...
Old 08-16-2006, 11:52 AM
Control Group
Tobra's Avatar
second the valve adjustment idea, it is very easy(done with cold engine), takes me about 20 minutes to complete all of the above
They should take a spare fanbelt too, just in case
Old 08-16-2006, 12:57 PM
GothingNC's Avatar
Don't forget to use new valve cover gaskets after the valve adjustment.
The're real cheap.
Also check around for exhaust lekas where the heater boxes connect to the muffler via clamps.
I wouldn't worry about replacing the sump screen, I just clean out mine and replace.
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
Old 08-16-2006, 01:07 PM
Control Group
Tobra's Avatar
I would not even worry much about taking the sump off if you are in a hurry. I always took mine off and it was alway mighty clean already.
May want to check the timing or something too if they are driving that far. Little too much advance on a type 1 VW motor and it gets mighty hot.
Old 08-16-2006, 01:09 PM
Feelin' Solexy
Tishabet's Avatar
The single handiest tool on long road trips in a beetle is your copy of Muir's book "How to keep your volkswagen alive." More tips and tricks than you would believe, still the high water mark for automotive repair journalism, IMHO.
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 08-16-2006, 02:36 PM
I'm not here.
K. Roman's Avatar
Thanks guys. I'd like to do the valve adjust, but don't know what to adjust, too rookie at this.
So, did the oil change, cleaned air cleaner and sump, and screen.
Old 08-16-2006, 03:21 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
You adjust the valves the same way you would on your 911. Do a search on the 911 board for valve adjust to get familar with the procedure. Afterwards, looks up the specs for a 1600 dual port. I cant remember them off the top of my head
www.thesamba.com is a great reference
I have a copy of the John Muir book if you need it as well
Old 08-16-2006, 03:31 PM
I've you've never had the sump plate off of this car, remove it. You never know what surprises are in store. I did the oil in my '56 ghia a week or so ago, and I was horrified at the crap that I found on the plate, and I was driving it like that (albeit just around the block
Do a google on +VW +"valve adjustment" and you'll get a ton of howtos, like this one: http://www.type2.com/bartnik/valveadj.htm
Old 08-16-2006, 04:23 PM
I'm not here.
K. Roman's Avatar
Thanks again for the info. No feeler gauge in my tool box, so we just did the oil, cleaned the filter, screen etc. Added a new rubber hose that connects to the right on the air cleaner (what's it for? Don't know) because the old one was damaged. then washed and dryed it.
I'll post a pic of it soon, the car is yellow with big colorful daisies painted all over it. It definately looks like a SF landmark on wheels.
The girl I know who painted it did it for AIDs charity. Each flower painted on it required some donation. She ended up donating 1,800 dollars to the charity.
Sweet girl.
Keith
Old 08-16-2006, 07:10 PM
Control Group
Tobra's Avatar
Sorry dude, I am a compleat idiot myself
This will have all you need to know, check out the Tech Talk with Rick and forums in particular. Has SB and Standard Beetle info
Superbeetles.com
Here is my old bug, fine handling little car, one of the cleanest old cars I have seen.
Old 08-19-2006, 04:28 PM
Here's my first car, a 1969 bug
And my current project, 1956 ghia
Old 08-19-2006, 04:44 PM
