Me like track days
I must have f'd it up on the laptop - takes 13 characters to do a 128 bit encryption. Did it.
Can't get a damn thing on it now, no internet access even after restart. ---- Shows connected to Linksys and with WEP security - including the padlock security icon. Heeeelp...
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
OK lets try to ping your router. go to a command prompt (start->run type cmd and press enter).
Type ping 192.168.1.1 and see if you get a reply. |
Me like track days
On the desktop - success
Laptop: Destination host unreachable
Try renewing your IP address. Go to a command prompt and type ipconfig /release then when the cursor comes back type ipconfig /renew.
If it still won't connect you may want to step down the weps encryption to 64 bit instead of the 128 bit. We had this same problem here at work. Just a thought.
Dan 2002 996 C4 Cab w/ Jake Raby 4.0 2024 Tacoma TRD Offroad 4x4 2003 Range Rover HSE |
is this thing on?
i have the same question, when i set up my lynksis wireless, I left it as an open unsecured connection. Can someone use the wireless to get into my other computers? how do i change it?
"People willing to trade their freedom for temporary security deserve neither and will lose both" ~Benjamin Franklin |
Me like track days
I go to Local Network, Linksys.
Leave top blank, Enter admin Won't let me in now. WTH??
From the laptop, goto Start -> Run. Type in "cmd" (not the quotes), a black box should appear. Type in ipconfig, report back with the I.P. number it gives. I bet it starts with 169.254.xxx.xxx.
Dave
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Me like track days
Comes back with:
Media state.................Media Disconnected
Reboot!
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Me like track days
Done. Reboot to both to home PC and laptop - same old situation.
---- I tried the Repair Wireless Network Connection on the laptop - came up with: Floowing action copuld not be completed: Renewing your IP address
This is interesting!
and you guys scoff at Mac users...this is just one reason why we use what we use. Airport admin app is very well behaved...and easy to use.
Me like track days
Slodave -
Comes back with 169.254.25.92 and then a default mask numer
isn't 169.254.x.x a "garbage" ip? I'm no expert (solve everything by trial and error) but I think this is a "bad" ip that will be generated when life isn't good. I'm sure the experts will chime in though. I'm always in awe of those that actually know what they're talking about :P
Me like track days
"You might not be able to access the internet or some network resources.
This problem occurred because the network did not assign a network address to the computer"
Network Connections. Double click on the wireless icon, select Properties. A window should pop up allowing you to select various network settings. Look for Internet Protocol (TCP/IP) select this and you should see a window that allows you to "Obtain an I.P. address automatically" or "Use the following address". Select the latter and enter the I.P. info I gave above. The important thing is to make sure you match the first three octets that the AP shows on the bottom of the device. Change the last octet to .100. Set the Netmask to "255.255.255.0". Then open a web browser and try to go to the AP address. Let us know what happens. Dave
Craig did you make any other changes to the security settings like locking down the MAC addresses, changing anything about the SSID, anything besides configuring WEP?
Me like track days
Slo - What's an AP?
930 - Only other thing I did was come up with a 13 'digit' password for the laptop to access the now WEP secured signal from the Linksys router. Guys, thanks a ton for the help, I gotta get the laptop working
Linksys 2.4 GHZ wireless access point router
![]() Gotta have lunch, about to fall over... Quote:
