Dept store Quartermaster
Edit: sorry., bit of a spoiler. Wasn't thinking.
Cornpoppin' Pony Soldier Last edited by lendaddy; 09-13-2006 at 07:40 AM.. |
Wouldn't the rubber bullet transfer as much if not more energy to the wood? Both bullets will come to a stop, thus imparting their kinetic energy to the wood. The rubber bullet, however, will store some of the energy inside itself as it deforms and then will impart some energy back to the wood as it rebounds.
Of course there is that energy cannot be created nor destroyed thingy to worry about...I knew I hated physics for a reason.
Rick 1984 911 coupe |
Cornpoppin' Pony Soldier |
Realistically I think both will knock the wood over.
Since I must choose, I'm going with the lead bullet due to the yield strength of each item. I think the deformation of the rubber bullet will absorb most of the energy, leaving little to move the wood. The lead and wood have similar yield strengths so the energy will be more even distributed leaving more energy to knock over the wood.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
I'll say the rubber one, since it would be less likely to penetrate the wood and dissipate the energy. Isn't that why they use them in riots?
I'm assuming that the area of impact is roughly the same, since they would be fired out of the same gun barrel. I may be wrong there.
72 914 2056: 74 9146 2.2: 76 914 2.0 |
In the shop at Pelican
If they are the same mass and travelling at the same speed, wont they both knock the wood over at the same time?
I really do hate physics...
This is fun
Unoffended by naked girls
You guys have never been to a bowling pin match....
Dan 1969 911T (sold) 2008 FXDL www.labreaprecision.com www.concealedcarrymidwest.com |
"agree, the only way I can figure is that there is energy stored in the wood from its position, i.e. someone put it on end and therefore stored energy in it which will be spent when it hits the ground. Therefore the wood has some energy stored which it can give back to the bullet when the bullet rebounds."
I think all the energy of compression would be in the rubber bullet, not in the wood. I would think wood is not very "elastic" Not to say it wouldn't bounce off the wood, just where the energy goes as it does. I think he must have read this in the Mensa quizzes on the airplane ride. ;->
was the monkey in the tree when the bullet was fired?
There had to be more than one shooter.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
edit: crap, totally wrong.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit |
Targa, Panamera Turbo
OK - here is the answer:
The rubber bullet will be more likely to knock the wood over. The lead bullet will embed itself in the wood, so the wood will have to absorb enough energy to stop the bullet's momentum. The rubber bullet will ricochet off of the wood, so the wood will have to absorb enough energy to stop the bullet plus send the bullet back in the opposite direction. The rubber bullet will supply more total force to the wood and will therefore be more likely to knock it over.
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
I call BS. someone get a log and some bullets... we gots an experiment to prove.
Problem is, none of these clowns would ever shoot a rubber bullet! Drop'm with lead or cut'm wit steel...
I think it's because the wood has to push back against the bullet in order for it to rebound. That energy comes from the friction between the wood and the ground as well as gravity which tends to want to keep the wood upright (until it gets to a 45 degree angle anyhow). If the wood did not push back against the bullet, it would simply fall over and there would be no rebound.
I still really hate physics.
