circuit breaker query
And now for something entirely different.
The circuit breaker controlling the clothes dryer in my mother in-law's rather old house on Long Island is going bad. My brother in-law read the folllowing information off the 2 pole 120/240 vac breaker. 8-5AL 10-000 120/240 SUELLQ 414 TYPE MP CU/AL Anyone know the brand or where I can get one before I fly back there and replace it? thanks |
The easiest thing to do is check the brand of the panel, and whether it is a full-height or half-height breaker, and whether it is packaged with other breakers.
Siemens likes to make 4-packs of half-size breakers with twin-pole breakers in the middle. Things like that are important. The actual numbers off of the breaker are not as important. I'd expect just about any home depot will carry the breaker you are looking for. Expect ~$25-$40 for a 2-pole 30A breaker (dryer should be a 30A circuit). I wouldn't worry about tracking one down before you go back there. Go in, remove the old breaker and take it to Home Depot or the electrical store of your choice. On a related topic, what do you mean the breaker is going bad?.... Nuissance tripping? Not tripping?....
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury! Buy my parts! |
Senior Member
One thing to be careful about is that new wiring codes have gone into effect in many cities. They took the old three wire dryer cord's to a four wire cord in most if not all areas.
Might be a good time to change both the CB and upgrade the wiring to the dryer just to make it safer.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Joe, What's the fourth wire for?
Warren & Ron, may you rest in Peace. |
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain |
Yeah, that's a good idea , Joe. I'll look into that. The house has been added onto throughout the years. There is still a fuze box with the round glass fuses in the old section. I doubt if this is a four wire dryer setup and I'll check. I'll get more info. But I think it is a Crouse Hinds box, and it has GE, Westinghouse and Thomas and Betts breakers in it. And I think it is a standard double wide 30A breaker, although he can not see any amp markings on it.
The last time I went to replace one of these breakers. I had to special order it as it was not carried at local Home Depot. Apparently it is tripping at startup of dryer, I'll check out circuit with voltmeter. They are holding it closed after startup and the dryer will run. I may need to put in a new dryer when I am back there.
steve old rocket inguneer |
Platinum Member
Could it be the dryer drawing too much start-up current (bad bearings in motor, friction somewhere..)? I would not hold the breaker till it runs.... the breaker is there for a reason.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Yeah, that's what I am thinking. If the new breaker trips also, then it will be a new dryer.
-Hampton |
you're looking for a murray (crap) 2 pole 30 amp circuit breaker. when the time for an upgrade comes go square d or cutler hammer.
Chris the more i learn, the less i know |
