Cars & Coffee Killer
legion's Avatar
Engine Balance
Educate me.
Inline four cylinder engines generally have balance shafts.
V8's have harmonic balancers on the crankshaft.
What do six cylinder engines have? What about V12s? Boxer 4's?
It seems to me that inline 4 and V8s should be a balance desinge, while V6's and Boxer 6's should produce tons of vibration. What am I missing?
5 liters of VVT fury now
-Chris
Old 11-20-2006, 07:48 AM
id10t's Avatar
356/912 crankshaft - Boxer 4 cylinder - http://www.aapistons.com/NewsInfo.asp?id=99
Old 11-20-2006, 08:28 AM
Un Chien Andalusia
Aerkuld's Avatar
The short answer is that there isn't a short answer. Engine vibration is determined by the number of cylinders, the bank angle (angle between the cylinders on a V), and crank offset angles, and ignition intervals.
I'll see what I can find that explains it...
Flaming complicated, but you get the idea. Hope it helps!
2002 996 Carrera - Seal Grey (Daily Driver / Track Car)
1964 Morris Mini - Former Finnish Rally Car
1987 911 Carrera Coupe - Carmine Red - SOLD :-(
1998 986 Boxster - Black - SOLD
1984 944 - Red - SOLD
Old 11-20-2006, 08:44 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
interesting to note that flat 4's, flat 6's, inline 6's and v-12's have no free forces or moments, which I believe means they're inherently balanced.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 11-20-2006, 09:04 AM
Bill is Dead.
cashflyer's Avatar
Nice text reference.
Do you have a machine shop?
Old 11-20-2006, 09:24 AM
Un Chien Andalusia
Aerkuld's Avatar
cashflyer - if you mean me, no, I don't have a machine shop as in own one, but I have spent a lot of time working in, around, or with them.
Old 11-20-2006, 09:34 AM
Gon fix it with me hammer
svandamme's Avatar
what Tim says ,
inline 4 is really a pisspoor design in terms of vibrations, V6 -8 - 10 aren't that much better either...
VW's VR6 on the other hand is a close call, as it is technically closer to an inline 6 then it is to a true V6...
once saw a swedish dude take apart a BMW V12 from a 760I ... after a gazillion miles, the main bearings hardly had visible wear on them...
Stijn Vandamme
BIMDIESELBMW116D2019
Old 11-20-2006, 09:41 AM
