I agree entirely. That and a Le Mans style start.
_____________________ These are my principles. If you don't like them, I have others.—Groucho Marx |
Unconstitutional Patriot
F1 needs drivers that believe rubbin' is racin'. You can get Dale Jr and Tony Stewart to mix things up a bit.
least common denominator
I look at the "official F1 site" to get time and location of the races.
Someone posted a link to "a good F1 site" but I'm too lazy to dig up the NASCAR thread. Anyone want to clue me in to some good F1 sites? How about they limit the teams to two set of tires a race, one wet and one dry? Of course they would be allowed to change tires in the even of a flat. I also don't get the "keeping expenses" excuse... that would be great if it were armature racing but this is supposed to be the exact opposite... the pinnacle of automobile racing.
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
Good F1 sites: atlasf1 (aka autosport.com - $50 yr), pitpass.com, grandprix.com
OK F1 sites: planetf1.com, itv-f1.com Proposal: Maximum total surface area for wings. No flex. The shape and number of wings is free. Non-wing aero devices - with an engine air intake exception - a maximum of two inches above or below their mounting surface. Mosely did make an interesting point recently - stating current F1 tech no longer has a beneficial impact on road car technology. The manufacturer's use F1 as a training ground for select engineers. Manufacturer's are concerned the over emphasis on aero development in F1 has no positive value for street cars. ROI is terrible. So. Expect to see a very large reduction in aero cost and development thru regulation change and a corresponding increase in mechanical, electrical, fuel, tech development in F1's future. We may even see different fuels for different engine capacities. We will see a lot of heat-loss and energy recyclable engine systems in the future. Tiny engines with turbos. The turbo era will return!!
Scott |
Unregistered
Everything they do to slow the cars down hurts the sport. 2.4 liter v-8 engines, no turbochargers, limited downforce, limited tires, limited qualifying, bah. If I wanted to watch indy car racing I would. Don't turn F-1 into indy or champ cars.
Un Chien Andalusia
A couple of other people have mentioned track size. Do you think that the tracks have effectively become 'smaller' with the increase in speed? I can see that this may be the case, a car doing 150mph will need a lot less space than a car doing 200mph. Maybe the straights do need to be longer, the corners wider. I wonder if there is a corner configuration that would allow multiple entry/exit lines? What about running the cars on methanol, like the champ cars use? Or even a high concentration of Methanol or Ethanol in gasoline? You get an immediate reduction in the calorific value of the fuel with the added enviromental benefits. It could also encourage interest and development into the oil-alternative fuels and be closer to what we will be seeing in road vehicles in the future. I guess that your unfavorable opinion of Champ cars is based upon the current series rather than the series that was, back until end of 2004? It USED to be a good series... I have no objection to the slamming of Indy car.
2002 996 Carrera - Seal Grey (Daily Driver / Track Car) 1964 Morris Mini - Former Finnish Rally Car 1987 911 Carrera Coupe - Carmine Red - SOLD :-( 1998 986 Boxster - Black - SOLD 1984 944 - Red - SOLD Last edited by Aerkuld; 12-03-2006 at 10:02 AM.. |
Un Chien Andalusia
The problem with some of these aerodynamic rules is that they get very difficult to control.
For instance, if you have a rule to limit the turbulence that a car generates how do you measure that? You can't realistically put every car in the wind tunnel each race. One of the comments on the relevance of aerodynamic downforce on road cars is valid. While a lot of other technologies have made their way from the track to the road, the use of downforce isn't very practical on a road car. The sport has definitely developed in that direction for the last 30-odd years, but a part of me wonders how interesting it would be to cut that line off and see what the next 'revolution' the innovators could come up with.
Re - aero rule enforcement. You're right - measuring downforce is difficult and expensive. IMHO, measuring surface area is cheaper and can be done at each race with laser scanning technology. You control a range of downforce and thereby its effect on leading and trailing cars by controling the effective working area of a wing - its upper and lower surfaces and leading and trailing edges. It would be cool to see a lot of different sized and curved wings or number of wings and elements, at different tracks - you could have four smaller rear wings or one big rear wing - up to the designer and lap times.
Regarding track size - changing the aero rules and maybe maximum brake pad square inches - would go the farthest to increase passing and different passing lines. Hungary was a great race this year just because of the rain. Rain has the same effect as reduced aero - it lowers grip which in turn increases skill requirements.
Scott |
Unregistered
F-1 is supposedly the pinnacle of open wheel racing because of the speed, power, and technology.
If you dummy down F-1 by putting more and more restrictions on power, down force, technology, it just becomes another series (like champ or indy). Focus on what makes F-1 better and emphasize it. |
If you want to make F1 competitive again with passing and stupid stuff like that, introducing the human error (by eliminating driver aids) and forcing the cars to go a different direction than wings etc is quite reasonable. If downforce is your karma, why don't you write to Bernie & Max telling them to bring back the "Fan" car?
Peter '79 930, Odyssey kid carrier, Prius sacrificial lamb Missing 997.1 GT3 RSnil carborundum illegitimi |
Slackerous Maximus
I think snipers would spice things up.
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
I'm with Bill
I guess no one watched last season because there were a LOT of very exciting races last year.
This next season should be very exciting too due to all the driver changes. I wish they would lift the 1 engine 2 races deal its making more costs not saving money. I actually like the new qualifying formet a lot its very cool and does not give anyone and advantage when it rains they are all out in it together. Its like 3 little races with the best one last. I think its the best format yet. I would like to see less downforce and loss of traction control. Leave anti lock brakes because they help a driver dive deeper and brake later. I would also like to see them lift a lmit on engine size and only limit output. This would allow teams to invent more.
1978 Mini Cooper Pickup 1991 BMW 318i M50 2.8 swap 2005 Mini Cooper S 2014 BMW i3 Giga World - For sale in late March |
Unregistered
F-1 was the pinnacle of motor sports before downforce because it featured the best technology, the best teams, the best drivers, it has always been the major league.
Slowing it down, taking away more technology, taking away tires, or engines, or whatever puts it closer to minor league. If they slowed the F-1 cars down so that they all ran the same speed, say roughly the same speed as ther go-karts at the local fun zone or miniature golf course, they would not go fast enough to generate down force and there would be more passing. If they take away all the tires and spare parts (including engines), the drivers would wave each other past with no blocking because they would be afraid to take a chance on breaking anything. How about if they are only allowed 10 gallons of fuel per weekend? i bet drafting and passing would really come into play then. How many of us have actually watched an F-1 car run in person? i have, it is simply unbeleivable. The sound, the speed, no way to describe it. Don't take that away or we might as well be watching malibu grand prix go-karts. I absolutely loved ther old can am series, where basically anything goes. Big engines, big power, huge wings, and small cars. That was racing. If F-1 becomes a spec racing series, I will not watch. Hear that Bernie? Yeah like he really cares. |
I'm with Bill
I think a HP rule would be good, you could run a turbo 4 or 6 or 8 or a V-10 or V-12 the only requirment is that you cannot exceed a given amount of HP be it 700 or 900 HP.
As we all know HP curves can vary greatly, suddenly you have a team developing an engine that has lots of power through the entire bend. Then we can benefit from better designed engines and turbo setups. I personally love the way it is now, these drivers are akin to fighter pilots except their fighter jets have wheels. I am blown away by how these car corner and how hard they can brake. I really do not think it is broke, except for Bernie and Max screwing with the rules to cut costs, last time I checked the whole appeal of this sport was the no expense spared approach to it. Right down to the motor homes.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
F1 has modified rules and regulations since the thirties and it has done so with no real reduction in status, excitement, or innovation. Regulation adjustment is necessary as new technology is introduced.
Scott |
Furthermore, even if cars have the same or different speeds, a missed downshift or upshift not only can break the car, but allows passing in the corners and reintroduces the importance of the driver - which has been sorely lacking. Then we'd get to see if Alonso is really as bad as others say or whether Schumacher is as good as some people think. Quote:
Insane Dutchman
Probably been said before, but I would:
Put in fuel metering, you can burn it however you want, but you only get XX cc/sec maximum, plus a limited tank capacity. Get rid of all but front and rear wings, limit their area, but shape is free. Minimum ride height, with flat bottoms to eliminate ground effects Set a maximum wetted area for entire car, preferably less than to day to make streamlining (and hopefully turbulence) smaller Limit brake size, material and tire width to smaller than today I agree with Max's concerns, just not his methods to get there. F1 will always be expensive and as long as people are willing to pay..why not? Dennis
1975 911S with Kremer 3.2 1989 911 Carrera Project Car |
Un Chien Andalusia
Apart from the lack of overtaking, which as Jim has pointed out seems to have been a bit better recently, the biggest issue still seems to be that there is a huge void between the top teams and the also-rans. This is why the cost cutting measures came about surely?
I wonder, when you break down the expenses of a top team, where the majority of the development money goes? Looking just at the car systems, not including engine, I would guess that aerodynamics is top of the list. The amount of time cars spend in the wind tunnel must get quite costly. Of course, most of the big boys have their own wind tunnels, and very sophisticated ones at that. The small teams have to buy their wind tunnel time, probably in a much less sophisticated tunnel. So would trimmimg down the benefit of aero make a difference? Maybe eliminating downforce and concentrating purely on drag? I would like to see a reintroduction of fuel limiting. I like the idea of a limited quantity for the race, but this brings substantial cost to an engine development program which is exactly what they are trying to avoid. On the otherhand, it is a benefitial development. What if teams had to submit technical papers to the FIA for every innovation before it is approved. The FIA then holds onto it until the end of the season and then release all the papers from all the teams at the end of the season. This would help advance technology in areas away from racing, while still allowing teams to develop their own ideas. I don't think that this would cut costs, but at least it makes the development beneficial to the world as a whole.
2002 996 Carrera - Seal Grey (Daily Driver / Track Car) 1964 Morris Mini - Former Finnish Rally Car 1987 911 Carrera Coupe - Carmine Red - SOLD :-( 1998 986 Boxster - Black - SOLD 1984 944 - Red - SOLD |
Aero is definitely the big dog in team expense. The top teams run 2 tunnels 24/7. And it has the least relevance to street cars which is why the manufacturer's want to reduce its importance in F1 and concentrate on other areas of development. Like fuel efficiency. Less heat loss.
FIA already requires teams to submit design specs and crash test results on each new chassis and car and every year. Every major change during the season also requires design spec submission and sign off by FIA tech (Charley Whiting). Case in point is the Renault mass damper. FIA had approved the submitted designs and use description and allowed Renault to put it on the cars. Renault ran it for a season and a half before FIA decided it was a movable aerodynamic device and really shouldn't have been allowed, after all. OOPS Easiest way to control downforce and reduce aero interference with passing is to reduce surface (wetted) area of wings like Dennis said. Then reduce the maximum braking pad area to increase braking zones and you get more passing. The rain races are exciting, fun, and show more driver skill simply because grip levels are reduces. The line between adhesion and slipping narrows and rewards the most sensitive drivers.
Scott |
