Great night for the furnace to fail...
It's 40F forecast 28F - record cold.
Furnace won't ignite. It has the heater equivalent of an OBDI error code: 14 = Failure to ignite. Brrrr. Good thing I've got plenty of wine...
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
Does it light and go off?
If so steel wool off that flame detector. No flame? Does the ignitor glow? |
Detached Member
The gas probably froze in the pipe
My wife says its about 30 degrees outside of our house north of Los Angeles. Its about 75 and partly cloudy here in Auckland after four days of rain
Hugh |
I pulled the hot surface ignitor - the silicon carbide element has a crack clean through.
Now to find one on Sunday...
don, eat some pasta; maybe fsm will help you out. separately, I watched ricky bobby nascar movie last night--absolutely hilarious, especially the baby jesus grace scene.
Warren Hall (Early S Man), 1950 - 2008 ------------------------------------ 2006 Tri D675 Scorched Yellow 2006 Ducati Sport Classic mono SOLD 1979 SCWDP #0020 Talbot Yellow SOLD |
Senior Member
Was down to 25 this morning when I woke up here in Phoenix. Thank God for fireplaces!
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Used to be Singpilot...
Location: Sioux Falls, SD is what the reg says on the bus.
Here on the water in LaLaLand it got down to 49 last night. Sea temp was 66.
Was a rough night in the slip. |
Senior Member
Michael,
What do you have for heat on the boat? Gas heater? Sea temp would help but still would be chilly...
bring water to slow boil on stove......... moisture=heat.
My heating system stopped working last night, been flakey for awhile but now it won't turn on at all.
House was 53F this morning, unpleasantly chilly. 36F outside, around 25-28F at night. Have a little electric heater plugged into the living room outlet, trying to heat all 3300 sq ft of house - and faiing. Furnace repair guy on his way. I went down to look at the furnace but couldn't make heads or tails of it, and considering it handles gas and electricity and runs unattended in the basement, decided not a suitable topic for DIY experimentation.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
Try the thermocouple. Most hardware stores sell them in different lengths. The always fail after a few years and are simple to replace.
"Igneous Aquam et Laudi semper" Carl Muckley |
