scanning slides, 35mm negatives and prints
What equipment would be needed to scan slides, etc. at home? What quality can you expect vs sending them out to a pro?
Don't know much about the process other than I have used a few scanners over the years. Thanks |
Senior Member
I scan them using a HP flatbed scanner and the adapter included. Its not pro quality but descent enough. For good stuff I have a Primefilm scanner that does excellent work.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
I recomend a dedicated 35mm scanner for slides. They are quite cheap nowadays and can be bought used.
Flatbed just isn't up to it. They have the theoretical resolution but results are bad.
Thank you for your time, |
Senior Member
As noted above, am using a Primefilm dedicated film/negative scanner for the good stuff.
Joe
I was reasoning this way: slides are analogue and are easily scratched/destroyed. I scanned everything using highest resolution available and saved them with lossless compression. That way, I would have maximum resolution should I ever need to go back. For continuous small-volume work, there are nice USB 2.0 film scanners as Nicon Coolscan LS-50 etc. If you have a big bunch of negatives/slidesthat you plan to save for future generations by digitizing them, I suggest turning the wads of slides to a photo shop and letting them digitize everything in their automated photo scanner (ask for highest resolution). They probably won't achieve proper hues/saturation/balance for each frame but they'll digitize hundreds of frames cheap and easy. Otherwise you'll grow tired of doing it manually. It usually takes and hour (if you are fast!) for one 36-frame film roll to do it by hand. On the other hand, If you plan to do play with it and explore your "artistic" side then by all means, get a film scanner and fool around with it...scan, check the results and do it againt etc. You will be able to get very good results, albeit at a cost of time. If you have a very very good middle-format shot thatt you plan to digitize, it's time for a pro. I sent my best 'blad 6x6's (few chosen shots) to a shop with a drum scanner, and asked for wet-mounting. That's the best you can get. For everything else (35mm Leica stuff), 400 bucks worh of film scanner is good enough. IMHO, flatbed-scanner is only usable when digitizing making a whole bunch of negative contact-copies, in order to weed out the bad ones. It's CCD has the raw resolution but optic artifacts and noise make it a bad solution for anything else but web work. For more info, check the net: http://www.photozone.de/2Equipment/scanner.htm#entry If possible, digitize with maximum bit-depth and full resolution. Storage is just getting cheaper. Copying files to bigger drive is easy. Restoring burned/scratched slides is impossible. Good luck!
Thank you for your time, Last edited by beepbeep; 01-24-2007 at 06:56 AM.. |
Information Junky
Re: scanning slides, 35mm negatives and prints
With a bright white background, far behind the slide, and a relatively dark space between the camera and the front of the slide, I found some excellent results. The camera needs to have a macro setting at full zoom (to minimize any 'fun house' effects and for full frame. .. to utilize the most pixels.) Or, for some digicams, you can buy a slide adaptor, which fits on the camera lens. --those work like an old Viewmaster . ..but for your camera. Of course, like those old Viewmaster's the light source you point it at needs to be clean/white, else color distortions may occur on your image. --otherwise, beeper covered this topic well.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
