Detached Member
Hugh R's Avatar
I need an Electric Dipstick, can anyone help?
It seems they don't stock these things here in SoCal. NAPA and Pep Boys gave me a blank look. I used to own one 25 years ago, but can't find it. I need it for the Aston Martin rebuild (tight bearing clearances). Can one of you cold weather guys help a brother out? I can paypal or send cash for the dipstick and shipping. I need one with an insertion lenght of 21", or so, and no more than 1/4" diameter. Thanks for any help.
Hugh
Old 01-27-2007, 05:06 PM
Wink
Never found it that hard to pull mine out manually! Btw...Happy Birthday!
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 01-27-2007, 06:01 PM
Hell Belcho
Nostril Cheese's Avatar
for heating up the oil?
Old 01-27-2007, 06:15 PM
Detached Member
Hugh R's Avatar
I suppose I could modify an electric antenna to do the trick
Nostril:
Yeah, exactly to heat the oil and to expand the clearances on the main bearings so it will spin easier and not give my starter motor a heart attack. I figure half a dozen heat cycles and it'll loosen up the main bearings. I set them really close, where they're supposed to be at 0.00125" to 0.00150" btw, a piece of computer paper is about 0.004" thick.
Anybody? I Googled them and found a sold one on ebay, but no other luck.
Hugh
Old 01-27-2007, 06:33 PM
The Unsettler
stomachmonkey's Avatar
JC Whitney has something.
http://www.jcwhitney.com/autoparts/Browse/tf-Browse/s-10101/in_dim_search-1/N-111+10201+600001648/c-10101/TID-8043876
"I want my two dollars"
"Brandon Won"
Old 01-27-2007, 06:36 PM
The Unsettler
This looks cool.
http://www.maesco.com/products/kim/kimlube/kimlube.html
"Brandon Won"
Old 01-27-2007, 06:38 PM
The Unsettler
Here's a 21 on ebay htat ends in an hour
http://cgi.ebay.com/ebaymotors/New-Universal-Dipstick-Engine-Block-Oil-Heater-HotStart_W0QQcmdZViewItemQQcategoryZ33613QQihZ016Q QitemZ260078992606QQrdZ1QQsspagenameZWDVW
"Brandon Won"
Old 01-27-2007, 06:43 PM
The Unsettler
sorry, ends in a day. my bad
"Brandon Won"
Old 01-27-2007, 06:45 PM
pwd72s's Avatar
Maybe I'm over complicating things...wouldn't it be better to rig a way to heat both the block AND the oil, begin the expansion process beyond merely warm oil? The problem with JC whitney? SHIPPING...they really ding you on shipping. Perhaps one of our brothers here living in the great frozen North could buy a heated dipstick in a local parts store & mail it to you?
The Unsettler
My father used to use the coolant hose variety for that purpose and also you get heat faster.
But really you want to warm the oil and motor if possible. Warm oil travelling thru a cold block will get cold real fast.
The coolant hose heaters circulate thru the system so the block and everything in it stays warm.
"Brandon Won"
Old 01-27-2007, 06:49 PM
VincentVega's Avatar
What about something like this?
http://www.dieselproducts.com/proheat/proheat.html
Old 01-27-2007, 06:59 PM
pwd72s's Avatar
Go with local knowledge...
Old 01-27-2007, 08:17 PM
Detached Member
Hugh R's Avatar
I'm in SoCal, this is a one time thing. I don't need a block heater, I just need an electric dip stick.
Hugh
Old 01-28-2007, 12:34 AM
Drain the oil and bring it in the house, heat on the stove/oven?
I would maybe do this when wife was gone.
I can't quote years or models but the early Honda multi cylinder racing bikes required heating three different weights of oil to get the thing running.
Jim
down to jap bikes that run and a dead Norton
Old 01-28-2007, 07:58 AM
Senior Member
Jim
This is what we do for airplanes. As well if its really cold we use a oil tank heater.
Hugh, drain the oil and warm it on the stove then pour it in the engine when you intend to start it.
Pre-lube the engine by turning it over with the warm oil inside then put the coil wire in and fire the puppy up!
Old 01-28-2007, 08:18 AM
another round please
strupgolf's Avatar
I've got one I dont use very much. Its 23" long. Send me your address and I'll get it out to you tomorrow. I just found it in my cold-cold-cold garage. Its only 17 today. When you're done with it, send it back. On second thought, keep it. I dont think I'll ever need it again.
Getting old is not for wimps.
Detached Member
Hugh R's Avatar
Way too coooool! PM sent.
Hugh
Old 01-28-2007, 09:51 AM
