lonewolf's Avatar
i gave you step by step inst in the pm i sent.
you have no fuel in bowl because when you drained it the the tiny bit of fuel that was left dried up and the needle is stuck closed
Old 02-13-2007, 03:48 PM
on-ramp's Avatar
lonewolf, yep...i'm guessing that the most likely culprit.
I will call you in the AM. thanks.
Old 02-13-2007, 03:51 PM
on-ramp's Avatar
so after pushing on the spring-loaded pin, and no fuel coming out, I decided to undo the nut that holds the float bowel in place.
fuel starting leaking all over my garage floor.. not good.
i quickly re-installed the nut.. to my amazement. now when i pressed on the pin, gas came out.
tried it again with the electrical start, and started right up!
thanks so much. this would've been a nightmare to do with a shovel. this board rocks!
lonewolf you have PM.
Old 02-14-2007, 08:02 AM
stevepaa's Avatar
The same thing will happen to dirt bikes with SU style carburettors.
steve
old rocket inguneer
Old 02-14-2007, 08:57 AM
19 years and 17k posts...
azasadny's Avatar
I always had to use starting fluid for the first start-up of the season even though I put StaBil in the gas tank when I put the snowblower away for the season. I decided the snowblower was more trouble than it was worth. My 15yr old son gets to shovel now!!!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 02-16-2007, 04:06 AM
TSNAPCRACKLEPOP's Avatar
i was just about to suggest that you get the shovel and quickly shovel snow into the intake to jump start it.
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 02-16-2007, 06:05 AM
Sounds like when you pulled the bowl cover off the float extended further than usual and freed the pin. Good work.
Our big storm turned out to be 2".
Warren & Ron, may you rest in Peace.
Old 02-16-2007, 08:24 AM
lonewolf's Avatar
exactly!
Old 02-16-2007, 10:03 AM
