meister member
speedracing944's Avatar
compression = 0 on #2 cylinder Saturn SL-2. now what?
I was driving home from IL last night and the car lost power. It seemed to be running on 3 cylinders. I just check my compression and
#1 is at 185
#2 is at 0
#3 is at 190
#4 is at 185
so what shall I do next? leak down test? get ready to pull the head?
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 02-04-2007, 11:28 AM
Gon fix it with me hammer
svandamme's Avatar
leakdown is an option , then you can hear the air escape via intake or exhaust, and maybe even determine which valve dropped
Stijn Vandamme
BIMDIESELBMW116D2019
Old 02-04-2007, 11:56 AM
Banned
Or you could just take out that plug and keep on going.
I had a customer with a Honda do that back when I was wrenching on cars. The dude put a 100k on it like that.
He was not our best customer.
Old 02-04-2007, 12:54 PM
klaucke's Avatar
Somethings definately wrong, the head will have to be pulled either way. Why even bother w/ a leakdown, just take the head off.
Old 02-04-2007, 12:56 PM
meister member
It seems like it could be one of 3 things
head gasket
intake valve
exhaust valve
I will have to pull the head and go from there. The head has "porosity" problems according to the service tech at the Saturn dealership. I guess it is pretty common for the SL-2 to leak coolant through the porous head.
Speedy
Old 02-04-2007, 01:46 PM
Banned
If you can leak coolant through the head, why are there no exhaust gasses getting in there? That makes no damn sence to me.
Old 02-04-2007, 02:03 PM
Get a big drill bit and drill three more holes to even the compression out between all 4 cylinders.
Old 02-04-2007, 02:19 PM
Banned
fastpat's Avatar
It's a Saturn, throw it away and get another one.
Old 02-04-2007, 03:25 PM
meister member
I would throw it away and get another P-car but I am in my second year of Engineering School. I was hoping this car would last me through school without big trouble. The big bummer is it is -15 degrees F outside right now and have the project 948 torn apart in the single car garage. I will have to get creative in how I fix it.
I thought about just pulling the fuel injector plug out but I am sure it would mess with the fuel injection by richening the mixture.
Well best start looking for a head.
Speedy
Old 02-04-2007, 03:56 PM
Send a message via AIM to SlowToady
You know, while you're in there, there are some pretty sweet Turbo setups for Saturns.
You know...while you're in there....
I turn away with fear and horror from this lamentable sore of continuous functions without derivatives. --Charles Hermite
Fakelife.com Nothing to do with archery anymore. Porsche/BMW/Ferrari/Honda videos
Old 02-04-2007, 04:08 PM
I'm with Bill
Rick V's Avatar
Pull the engine and install a "Vette" powerplant. I suspect the trans would have issues though.
Finding a head for the SL2 is hard, at least in my neck of the woods
Old 02-04-2007, 04:40 PM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
One solution...Buy a Japan made car...No more engine problems...!
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 02-04-2007, 05:21 PM
Registered abUser
TerryH's Avatar
Perhaps just a valve spring?
'81 911SC Coupe SOLD
Old 02-04-2007, 05:37 PM
Cars & Coffee Killer
legion's Avatar
You could finish the 'S'...
5 liters of VVT fury now
-Chris
Old 02-04-2007, 07:32 PM
meister member
holy cow. Today the olds van battery died and the fuel pressure regulator was leaking as well. I fixed those items tonight but I feel like I angered the car gods somehow. I must be down on my good karma levels or something.
Speedy
toady,
you have a link to the turbo setups you speak of?
rick,
I don't think the LT1 engine will fit plus could you amagine the torque steer on that sucka!
Legion,
I know, I know, I should have finished the 'S' because then this wouldn't be a big issue.
I saw a 83 944 in our local paper for $1600. I started to think about dumping the Saturn and getting the more reliable 944.
Old 02-05-2007, 05:38 PM
meister member
**** update ******
Pulled the valve cover and everything looked OK with the valaves and springs. I called the dealership and they said they rarely have head gasket problems but have had problems with the exhaust valves blowing holes through and chipping. I unplugged the fuel injector and drove it until today. The Saturn dealership quoted over the phone $675 to do the head gasket and to replace the valve. I thought it was reasonable so I made an apointment. I took the car in this morning so they could pull the head and call me back with a damage report....
I just got a call at 6:00 pm which is when service closed. The service manager said they havn't pulled the head yet but did run a compression test. He said they got
140
0
125
140
He went on to say Saturn's low limit is 165 so the motor is shot and I need a new one. He them quoted me $3,500 for a remanufactured 1.9L I-4 . I almost died. Wen I told him the car wasn't even worth $3,500 he said it would be worth alot more with the new engine... BS!!! I asked to have them to just replace the bad valve but he said they would want to do all of them at a tune of $1000.
I am smelling a rat here! His compression number differ greatly from what I saw on my gauge in my garage and I think he is trying to soak me. (see compression figs at top of thread) It angers me soooo much I want to strangle him. I thought it was convinent he called me right at closing as if to pressure me into making a decision.
What are you guys thoughts??
Speedy
Old 02-22-2007, 04:55 PM
Who is John Galt?
Rondinone's Avatar
Have the car flatbedded to an honest mechanic.
'79 911sc Targa
'02 slk230 kompressor
'84 Tamiya Falcon
A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship. The average age of the world's greatest civilizations has been 200 years.
Old 02-22-2007, 05:08 PM
Check if the cylinder head has been replaced by a GM dealer before. There is (or was) a 6 year warranty on the early single cam cylinder heads.
Maybe the twin-cam heads have the same problem?
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 02-22-2007, 05:19 PM
Used to be Singpilot...
Location: Sioux Falls, SD is what the reg says on the bus.
I just convinced a GF to get rid of her SL2. The clutch went out. The dealer wanted a thou to do it. The car was not worth that fixed. There were no independants that would touch it. It went to a 'recent visitor to this country' and onto a flatbed trailor.
Old 02-22-2007, 05:56 PM
legion's Avatar
I call this particular game "dealership".
Take it to an independent. Although considering you are putting a V8 in a 944, I'd think you were capable of doing it yourself.
-Chris
Old 02-22-2007, 06:00 PM
