Updated: 55 min 22 sec ago
» Disable Rapid Fire — About Rapid Fire Observed at: Los Angeles Downtown, California Elevation: 256 ft / 78 m 60 °F / 16 °C Overcast Humidity: 80% Dew Point: 54 °F / 12 °C Wind: 4 mph / 6 km/h / 1.5 m/s Variable Pressure: 30.00 in / 1016 hPa Visibility: 10.0 miles / 16.1 kilometers UV: 0 out of 16 Clouds: Overcast 600 ft / 182 m (Above Ground Level)
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Hell Belcho
gets real cold in the south bay dont it?
Saved by the buoyancy of citrus. |
You do not have permissi
http://www.shopping.com/xPO-Nighthawk_Combo_Gas_co_Detector~r-1~CLT-INTR~RFR-www.google.com
~$55 in the furnace room. Combo gas/CO detector.
Meanwhile other things are still happening. |
Retired Member
Is the leak concealed or underground after the meter? If the gas lines are concealed it would be a good idea to have them pressure test the lines after the repair.It's a PIA because you have to isolate the lines from the meter, and ALL the appliances. The reason for that is the incoming pressure after the meter is usually 7-11 inches water column,which is roughly 1/4 of a pound. 28 inches water column is a pound.
The pressure test should be 15 pounds ( I use nitrogen) for 15 minutes. That is what the gas code in Ontario calls for.
80 911 SC sold 17 Tahoe 07 Z06 Corvette
wayne thank blessing no one hurt gas leaks a dangerous the gas is colorless and oderless most gas company put an additive so you can smell the gas and as a firefighter i've been to scenes where whole family's were lost to undected gas leaks .please get a gas dector installed ,i know in cali most lines run under the houses crawl spaces so not as bad as line run thru the walls in big buildings .
pca 30 year member,1977 porsche turbo body targa 56 vw ragtop oval 01 harley sportster 18 Chevy Colorado diesel BIG RED Firetruck and assorted v-dub ,porsche parts hoarder..LoL |
Retired Member
The additive is called mercaptin.
Kaboom!
2018 VW Golf R 5 door + 1991 Mazda MX5 Eunos + 2010 MX5 folding hard top. Nikon D810 SLR and a gazillion lenses. Lumix LX3 and Canon SX720HS (40 x zoom) , Leica DLUX 109 (really a Panasonic) |
canna change law physics
There are many Mercaptans. Skunks make mercaptans. The skunky flavor/smell in some beers are mercaptans. Even the funky smell when you pee after eating asparagas is a mercaptan.
Back to the gas leak. Wayne. You can afford a hotel room for a few nights. It isn't worth your life or your family's.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Detached Member
Turn off the pilot lights and the pilotless ignitions, refrigerators too cause their motors aren't explosion proof. and don't turn on lights. And/or open up some windows. Go outside to smoke the cigar.
Hugh |
My second home I put a 90 % effecient furnace in my garge. It vented in side so no piping to run except the gas pipe.. For 3 years we always smelled something but figured it was the smell from changing oil etc and those fumes being consumed by the furnace and reburned to make the great smell. when we chose to sell the home the inspecter came in and said we had a leak.. It was in the gas pipe that had to be turned 4 full turns.. my wife said"told you so" so again I had to tell her she was right!!!
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Which is a cautionary tale to put a garage gas heater "outside" the structure in its own enclosure, with only the returns and heated air return penetrating into the structure being heated. Eliminates the danger of explosive gases entering the heated space. Out here, without basements, the furnace and water heater are in a separate room, "sealed" (gasketed) from the living space, with a considerable amount of venting to the outside for any conbustible gases which may leak or CO which might not all go "up the pipe".
Bob S. former owner of a 1984 silver 944 |
Wayne, remember that all gas leaks are dangerous. The detector will tell you there is a combustible gas present, but do not rely on the "level". From the point of leak, as the gas mixes with air, you will have an area above the explosive limit, an area at the explosive limit and an area below the explosive limit.
Please be careful.
