RallyJon's Avatar
Question Push-on Hose for air/water?
I need to do some air and water hoses involving 90º fittings. Browsing through the McMaster catalog I found push-on hose, which looks easy for DIY and has a nice selection of ends available. Page 254 at http://www.mcmaster.com
Is this type of fitting reliable for long term use? No clamps--it just "pushes on" to a special barbed fitting.
Push on fitting are rated for 350psi with no clamps. Traditional barbed fitting with a clamp are only rated for 150psi. I must be missing something...
993 · 911 · STI · S4 · rally car
Old 03-09-2007, 06:03 AM
Slumlord
Porsche_monkey's Avatar
That type of hose is standard in the machine building industry, simply push it on (without oil as a lubricant) and it is definately good to 150 psi. And they are very good.
I think the ratings posted refer to the fitting rated pressure, and the hose rated pressure, not the assembly with the hose on the fitting. To got o 350 psi I would use a proper clamp, but at 'normal' pressures no clamps are used or required.
What exactly are you using them for?
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 03-09-2007, 07:16 AM
Registered abUser
TerryH's Avatar
Push-Lok hose and fittings are well known brand names(Parker) in industrial use and are designed for water and air.
http://www.parker.com/hpd/literature/pdf/4281_b1.pdf
'81 911SC Coupe SOLD
Old 03-09-2007, 07:22 AM
RallyJon's Avatar
Home shop compressed air (150psi occasionally) and water (80psi continuously). Both hoses will be approx 4 ft long and connect hard lines to hose reels.
Old 03-09-2007, 07:33 AM
Registered abUser
TerryH's Avatar
That's precisely what they are designed for. In my home or garage, I would still use small worm clamps for added insurance. All hose degrades eventually and things happen.
Old 03-09-2007, 07:37 AM
Slumlord
These are very good, and do not cutinto the rubber covering the way some gear clamps do;
http://www.oetiker.com/usa/start_pr_ksr_e.htm
But they are definately optional, a properly installed Push-lock hose will fine for what you are doing. Press them on with a bit of soapy water, no oil.
84 Cab - sold!
Old 03-09-2007, 07:46 AM
Unconstitutional Patriot
turbo6bar's Avatar
The hose from McMaster is rated for air only, according to the page.
I have used the equivalent auto stuff, Aeroquip AQP. It is really tough stuff. I bought my bits from a local bus repair shop that also sold hydraulic fittings. The fittings were brass and price was right.
Old 03-09-2007, 09:18 AM
Slumlord
Just buy Parker Push-lok. This is not a place to economize. You'll own this stuff for a long time...
84 Cab - sold!
Old 03-09-2007, 09:46 AM
turbo6bar's Avatar
I just looked at the .pdf for Parker Push-Lok. The fittings and hose are identical to the Aeroquip AQP I have. It would not surprise me if the manufacturer is the same.
Old 03-09-2007, 10:01 AM
