pmajka's Avatar
Temporary Caulk???
I have a Air leak in my front door...sure they sell a seal of sorts. that you need to hammer in then there is the sweep at the bottom that never fits.
I use the front door 2 - 3 times a year and never in the winter.
Is there a temporary caulk I can use to Seal that thing air tight????
Have you ever felt suffocated while watching the Oxygen Channel?
People with excuses fail. As soon as I OK my actions with an excuse, I cease bettering myself.
88 Carrera
Old 03-21-2007, 03:59 PM
Can you tuck a piece of soft cotton rope or foam in the gap?
Warren & Ron, may you rest in Peace.
Old 03-21-2007, 04:06 PM
MRM MRM is offline
I'll need more information to tell whether caulk will do the job, but odds are that a little backer rod stuffed into the crack, covered by some high quality silicon caulk will be a near permanent fix. Can you describe the door and the door and the area where the air leak is in more detail? Is it a matter of putting a little more insulation under the threshold and raising the threshold a little?
MRM 1994 Carrera
Old 03-21-2007, 05:33 PM
Registered abUser
TerryH's Avatar
If it's at the bottom just fold an old towel enought times to get the proper thickness and slam the door on it.
'81 911SC Coupe SOLD
Old 03-21-2007, 05:44 PM
Re: Temporary Caulk???
Yes! They sell it at Home Depot. It's in the caulking area and is designed to be used and removed easily. I am thinking about using this in my office that has horribly inefficient windows that leak air. I didn't want to permenantly seal them and this stuff will let me peal it off if I ever need to. Good Luck.
Old 03-21-2007, 06:38 PM
