Recreational Mechanic
I have heard a few JB Weld stories like this....you can't argue with results!
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
There is a High Heat JB Weld now, specifically lists exhaust manifolds
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Still Doin Time
When I was a teenager, doing mechanical work on the side a guy brought me a '67 Chevy van ( unibody ) the ol 250 / 6 was smoking, been over heated so much that it blew the head gasket between 3-4 cyl. He didn't have the money to replace it, I didn't have the place or tools to drop the engine out the bottom.
Upon disassembley - found the deck surface was ' flame' worn between 3/4 where those cyls where trading combustion process. Also #3 had severely scored wall. I pulled the piston / rods out, used JB weld to fill in deep crevis in cyl wall and on the deck surface between 3/4. I let it sit 2 days, took an air body file to the deck, used a straight edge to check it. Then honed the cyls. I obtained 1 new piston and ring set, reused the rod bearings, installed new top end gaskets and... VIOLA !! That thing ran for I know 3 more years and had zero blow- by. As others have said - good stuff!
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Maybe I should buy that d-chunked 996
Functionista
I once tore down brake calipers down that had JB weld type stuff in the pits to keep from tearing the seal. I could barely pick it out with a pick. A little scary there. But maybe they would just leak a little like before.
Never seen it last in cooling systems though. The hot/cold cycles would eventually cause it to lift.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Thread Tools | |
Rate This Thread | |
