Student of the obvious
Suggestions on '94 Chevy S10 intermittent running problem?
Vehicle in question is a 1994 Chevy S10 V6 Vortec 4X4. I bought it not running. Fuel pump fuse was blown. Started right up after replacing the fuse. It hasn't been driven more than a few miles since. Today I'm driving along and I feel it lose power and die. Pulled off the road. Several attempts to restart failed so I called a tow truck... then it started. Cancelled the tow and started driving. It would get a mile or so and then die again.
Took it to a chain repair shop assuming it needed a fuel pump. The shop got it to die several times with a pressure gauge in place. It's not losing fuel pressure. There are no trouble codes showing up. Any suggestions?
Lee |
Senior Member
How about a new fuel filter, then pulling all the injectors and cleaning them?
Also, if the car is getting warm, wonder if something in the electronic ignition is getting warm and shorting out? Then cooling a bit and running until it gets warm again?
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Bad ignition module? Cam Position sensor? Bad Coil?
Next time it dies, see if you get spark.
Brent Early85 944 LM6Y Paint Code |
Re: Suggestions on '94 Chevy S10 intermittent running problem?
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Banned
2 things
1. Module 2. Coil I would bet money on it. |
Parrothead member
Sounds like fuel filter...
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
If it will start right up when the engine cools, it is probably a pickup coil. This exact thing happened to my '92. Pull the distributor and you can replace the pickup coil for under $100. It was a pain to figure out though.
It could also be the fuel pump. They do go out on these. Get the heavy duty replacement not the stock replacement and it will last forever. I have had lots of these S-10's. Good trucks. My dad's old '91 that my brother drives now has 211k on it and still runs strong.
*************************** '97 Saturn SL (tiny 1.9L bubble car) '98 Grand Prix GTP (4dr family car with a bite FOR SALE) '87 944S (Sold as a German engineerd money pit) '78 Chevy 4x4 (What I drive when everything else is broke) Last edited by tobster1911; 04-25-2007 at 08:29 AM.. |
My buddy had one of these, and it would run fine for a while then quit, etc. Turns out part of the wiring harness was melted to the engine somewhere. It would intermittently ground out, but not all the time.
Patrick |
