Team California
Need help; sealing foundation crack:
Anyone know what I should use to seal this crack along the base of the foundation of this house? This is on the side where a sidewalk runs along and the sun does not shine. Is there a particular product and/or brand that anyone likes for this job? I'm assuming there is a tube of caulk-type stuff that will seal it and hold up to extreme weather variations. (It's in Minnesota). TIA as always.
Picture:
Denis |
Parrothead member
Waterplug hydraulic cement
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
Team California
Thanks Vinny!
Denis |
Parrothead member
Dennis its a dry power that hardens immediately. You can put it on a crack that has water puring out of it and it will seal it right up.
Now that i look at it closer, I think you might want to use something flexible. You are talking about the the joint at the sidewalk/wall ?
Team California
Yes, the crack between the sidewalk and wall. I was thinking something that comes in a tube and goes in a caulk gun.
Denis |
Senior Member
What in the world are you doing in MN??? Not home yet?
Hows the pup doing?
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Parrothead member
Ive used a caulking made by a company NP it think its called DU concrete caulking comes in an orange and black tube I know you can only get it in a builders supply ,its not the kind of stuff a home center carries.
I use a lot of PL Products ployurethane caulks in my work and I am impressed with their strength. Not water clean up, so they can be a bear to use. They make a gray for concrete. About 4 bucks a tube.
canna change law physics
They just fixed some cracks in my new pool. They set small ports into the crack in epoxy, 8 hours later they pumped high pressure epoxy into the ports.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 Last edited by red-beard; 06-03-2007 at 07:56 PM.. |
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Friend of Warren
The area where the crack is at is going to move alot so I would recommend against anything that is not flexible. We have a concrete pond built in 1926 when the house was built. Had a number of cracks so it wouldn't hold water. I went to Lowes and got concrete caulk. Comes in light gray and dark gray. Has held up well to all the shifting of the concrete from summer to winter. That is what I would recommend.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Platinum Member
Is this a cosmetic repair, or are you trying to solve a problem? If cosmetic, just use a flexible grey caulk.
Red- Why did the new pool crack?
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
James, interesting product. Since I do some epoxy repairs and restorations, I can maybe use something like that or make up something similar in the shop. Thanks.
Matt J. 69 911T Targa - "Stinky" 2001 Boxster "Stahlgewehr" |
Who is John Galt?
Re: Need help; sealing foundation crack:
'79 911sc Targa '02 slk230 kompressor '84 Tamiya Falcon A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship. The average age of the world's greatest civilizations has been 200 years. |
Team California
Thanks, guys. I've been away from the computer all day so I'm just seeing this. I'm not sure if the crack is causing any real problems, (not my house), but it just seems logical that you would not want water going in there.
I'll check with a builders supply place in town here for the best nuclear strength flexible caulk and apply it. Joe, I've been gone a while, huh? I'm in MN. now hanging with family and friends and I've been fortunate enough to get roped into some work/$$. Not sure exactly when I'll be home.
Denis |
Sikaflex would work.
I tend to use mostly Tremco products. Tremco Dymonic would work fine. Use the best Urethane Sealant you can find. Try to find a local supply house which specializes in caulk. Not sure if HD or Lowe's carry a quality urethane. Make sure the crack is clean and very dry. Do a google search on tips for applying urethane sealants. Its extremely sticky when touched with an unlubed finger.
Randy '87 911 Targa '17 Macan GTS |
In a 6 inch thick concrete structure, a crack every 10 feet should be expected. Usually, a system is put in place to allow cracks in defined locations, then resealed. In my case, the crack split one of the flagstones in the coping, and with water coming though, it was thought it might go all the way through the gunite, so it was fixed. Better now, during construction, than later. Of course, it delayed the construction another week!
wow, denis..figured you were home by now! get to see anymore good museums or other presidential libraries, etc.?
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
