(the shotguns)
Anybody ever build a deck with a floating foundation?
Been thinking about using those pre-cast concrete piers (dek-block) for my deck as a way to save time and cash (ie divert more funding to the cash monster in the garage) and would like to know if anyone here has tried this. i kinda like the idea of a low to the ground deck with no railings and i could probably do this myself with minimal assistance.
thanks for any input- Erik
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Friend of Warren
As long as you are setting them on compacted solid ground you should have no problem using them.
Kurt V No more Porsches, but a revolving number of motorcycles. |
If you live in the northeast, the ground sinks with the cold weather. That's why the concrete tubes have to be at least 3 feet into the ground.
I recently built a multi-level deck and this was the case. You may want to check with your town about the requirements. |
I'll be using them when I replace my deck this summer. A low deck on deck blocks can be tweaked & adjusted, if needed.
In some cases, concrete tubes are way more of a PITA than they're worth. My ground really holds water and heaves dramatically. It "spit out" a 4' deep concrete post from my neighbor's yard, and his fence is set in 'crete and it moves every year.
Jake Often wrong, but never in doubt. '81 911 euro SC (bits & pieces) '03 Carrera 4s '97 LX450 / '85 LeCar / '88 Iltis + a whole bunch of boats |
(the shotguns)
i'm in Maryland and the soil the deck would be on is thick clay. it is a real beyotch to dig into at all. if i were to use the floating pier system i probably would not attach the deck to the house at all and just butt it up against the poured foundation. seems like it would be heavy enough not to move any but i am no expert on this stuff.
19 years and 17k posts...
We're pouring a concrete pad for a patio right now and my neighbor who's doing the work required me to dig the footings 36-40" deep. We have sandy loam soil and clay is 8' down, so it's easy to dig. According to my neighbor, we need to be sure the footings are below the frost line (we're in MI) and this will ensure quality results. Hope this helps...
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Slumlord
Yes, but it sat on 3/4" threaded rod and nuts to level it each summer.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Friend of Warren
If you are pouring footings, yes they need to be below the frost line. However, if it is a true "floating" deck, i.e., not attached to the house, then the above ground footings should work just fine. Again assuming they are not on soft soil where they would sink.
how do you think those footings would work on very rocky soil?
big blue tricycle stare down the darkness and watch it fade |
Dog-faced pony soldier
It's not just 3' into the ground, it's actually below the frost line. Yes, in most cases, 3' will suffice, but not always. . .
Do you have a soils report or any sort of knowledge where the frost line is? 3' will work usually, but if you're wrong you can get heaving of the footings and resulting damage to the structure.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
