Dept store Quartermaster
lendaddy's Avatar
AC question, why does mine suck?
My Tundra seemed like it wasn't blowing quite as cold as it should so I bought one of those recharge kits. The pressure was about 45lbs and when I charged it, I saw little change even though it took a whole bottle. Now today my AC is even worse, by a large margin.
Then today I tried a different gage and it reads 70psi! This is just past the upper end of "safe".
So what the heck? Any ideas what I did to ruin my AC?
Cornpoppin' Pony Soldier
Old 06-13-2007, 12:08 PM
kang's Avatar
I don't know much about AC's, but I do know that overcharging them is bad, very bad...
Downshift
Old 06-13-2007, 12:11 PM
lendaddy's Avatar
Can/should I bleed the whole system and start over? I have plenty of supplies.
Old 06-13-2007, 12:12 PM
MAGA
Tim Hancock's Avatar
I assume you checked the LOW side pressure with the AC running both times?. High side pressure, might typically be 150-250 psi depending on system and temps while low side might be 15-30 maybe. When you shut the car off, after awhile, the pressures will equalize and might read about 70 or so when the AC is off.
Too much or too little will affect how it works.
Do you have book with the correct high and low side pressure/temperature charts? Do you have a gage set that allows you to check both high and low side pressures while the system is on and running?
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 06-13-2007, 12:29 PM
lendaddy's Avatar
Book shmook Tim
I just released some and got it back down to 45psi. No dye is showing and the compressor is engaging. The sight glass is clear as well.
We'll see if it works again. Oh yea, it was the low side port.
Old 06-13-2007, 12:51 PM
If the AC sucks, could the fan be running backwords?
(That's a joke, len.....)
Bob S. former owner of a 1984 silver 944
Old 06-13-2007, 12:54 PM
least common denominator
scottmandue's Avatar
Well it sucks because when the compressor runs it sucks the freon in and blows it out the other side at a higher pressure...
Oh wait... that's not what you meant... nevermind.
What Tim said, there is a high side and a low side... check i t while running... blah, blah, blah...
Or you could take it to a garage and have someone who knows what they are doing look at it
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 06-13-2007, 01:00 PM
Oh and don't "dump it and start over", if you get air in the system you will really be forked.
It's supposed to be a sealed system if you are losing refrigerant it leaking out somewhere... and that is a bad thing.
I said "sucks" and "blows" all in one post!
Gary Fisher 29er
1995 Miata Sold
1984 944 Sold
Old 06-13-2007, 01:03 PM
Most auto parts stors sell a gauge kit that comes with instructions.
len..if my mind were not so preoccupied, I could help more. I have cert in automotive A/C. Good luck getting it fixed. Overcharging is a no-no. Usually 70+ on the low side says your compressor is toast. New compressor and dryer installed: $1300 to $1600. Hope this helps.
Old 06-13-2007, 01:05 PM
lendaddy's Avatar
I don't think Tim would respect me anymore if I did that, atleast until I've lost considerable blood and/or flesh first.
lendaddy's Avatar
Thanks Bob, hope things are going well on your end also.
Old 06-13-2007, 01:07 PM
Unconstitutional Patriot
turbo6bar's Avatar
70 psi to too high when the compressor is engaged. Try 35-45 psi. Do you have the factory Toyota manuals? I bet they have charts to check the charge.
Old 06-13-2007, 02:09 PM
MAGA
TRU DAT!!!!!
Pain is only temporary, but pride is forever!c
Seriously though, you did check the pressure with the system on and running correct?
0% Liberal
Old 06-13-2007, 02:56 PM
charleskieffner's Avatar
hey! do you have a in cab air filtration filter under dash pass. side. may be clogged.
when my 99 GMC K-1500 a/c starts blowing less, its always been the cab filter. nothing to do with a/c high low side, freon, seals, leaks.
replace for a few bucks and a/c blows ice cubes again
Old 06-13-2007, 03:05 PM
Semper drive!
rcecale's Avatar
Originally posted by Tim Hancock
TRU DAT!!!!!
Pain is just fear leaving the body!!!
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 06-13-2007, 03:35 PM
