Wash. State
nesslar's Avatar
Talking
Wil,
Just 'cuz it's kinda' fun, of course, as you know.
Old 07-14-2007, 08:09 AM
the the is offline
Originally posted by Wil Ferch
And...BTW.... the Chevy small block, even if cast-iron with aluminum heads, is not much heavier ( if at all) to our much vaunted , all-alloy flat six.
Having lifted (with help) many a 911 engine, and many a SBC, with iron and aluminum heads, I disagree.
A 911 engine (say a stock 3.0 or 3.2) dressed with intake and exhaust, is definitely lighter than a SBC with aluminum heads in the same configuration.
V8 in 911, who cares? 911s are plentiful and cheap these days (74-89) and there are lots of scrappy ones around. Have at it and have fun. But no way does the SBC weigh the same or less than the stock engine in any of those years. Nope.
And, BTW, this is of course a trolling thread, and one of the least creative ones, but so what, it's been a while since the "Could have had a V8" thread.
Old 07-14-2007, 08:25 AM
least common denominator
scottmandue's Avatar
Originally posted by Jim Richards
You put the SBC into the 951. Better HP/Torque and more reliable.
The 951 engine can be tuned up to 300hp with bolt-ons which is probably a lot cheaper than doing the SBC conversion... for that matter if you must have a SBC Porsche it is a lot cheaper to find one that has already been done and depreciated. YMMV
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 07-14-2007, 08:58 AM
Think Subaru
Old 07-14-2007, 06:11 PM
pwd72s's Avatar
Re: Valid reasons why I should not plug in a Chevy small block
Originally posted by CMDR Perry
I have an old German car (79 911SC) that is fun to drive and shift's hard like Dad's 49 Ford pick-up truck. I have also noticed that members of this forum like to knock SC's down in terms of market value when they are up for sale?
In my opinion my 911SC is underpowered, has a noisy valve train, leaks oil like a British motorbike and it costs a fortune to rebuild the engine.
Are there valid reasons why I should not install a 350 Chevy V8 next year? And please don't say it will reduce the value.
Old 07-14-2007, 06:31 PM
pwd72s's Avatar
Will....Cobras were first? Hardly. You forget Sidney Allard...
Old 07-14-2007, 07:34 PM
SCWDP911's Avatar
Originally posted by lowenslow
BTW, the 3.5 liter Brit motor (ex GM) aluminum v8 is an interesting idea with some potential, but it has some cooling & 'breathing' limitations that limit power potential. I tried a lot with my TR8, but the best it could do and still be streetable was 270-320 hp. The newer aluminum chevy motors (and various aluminum crate motors) have a LOT more potential for about the same weight.
I agree with you, but isn't that enough for our pseudo-sitch here? Even it was a later euro car (3.0), it would be a nice step up in HP, and I would imagine a hefty boost to torque across the band...
Shane
- 1984 928S
Old 07-14-2007, 08:33 PM
Bandwidth AbUser
Jim Richards's Avatar
CMDR, drop the V8 into your SC, and I'll send you a Gruppe B sticker to replace your SCWDP sticker. That alone will up your HP 5%.
Jim R.
Old 07-15-2007, 05:06 AM
hardflex's Avatar
why is it only Chevy's that get considered.? A small block Ford is very compact and the cast iron versions are a hundred pounds lighter than the small block chevy's . Aluminum heads are available too. I would like to do the swap into my 944 if conversion parts were readily available, but mostly because the timing belt's on the 944 engine look sooooo narrow.
72 914 2056: 74 9146 2.2: 76 914 2.0
Old 07-15-2007, 08:28 AM
Unregistered
sammyg2's Avatar
A 3 liter 911 engine fully dressed weighs aboyt 425 lbs.
A fully dressed 930 engine weights over 500 lbs.
A chebby sb with headers and an aluminum intake manfold weighs 475 lbs, with aluminum heads about 430 lbs.
But,, a 911 should never have less than 6 main bearings which rules out the chebby.
Old 07-15-2007, 09:16 AM
