Welding question
The rear sway bar mount broke off my dad's car, and he brought it over to have it fixed.
After dropping the sway bar, I had a guy down the road MIG weld the mount. He insisted that we disconnect the battery before he welds. He said that MIG welding could damage electrical components in the car. Makes sense, and I was glad to play it safe, but I had never heard of that before. Was he being overly cautious, or can MIG welding (or other types) actually damage electrical components?
Jake Often wrong, but never in doubt. '81 911 euro SC (bits & pieces) '03 Carrera 4s '97 LX450 / '85 LeCar / '88 Iltis + a whole bunch of boats |
Senior Member
He is correct. The diodes in the alternator can be damaged by welders. Good call on his part.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Certified Pre-Owned
In the basic sense MIG, TIG, and stick are a localized eletrical short circuit to heat the metal to melting temp for welding. Isolating a direct ground path back to the welder by disconnecting the battery is a wise move.
'84 Carrera Coupe |
Good to know, thanks!
JW Apostate
On the flip side, I've done close to 20 hours of welding on my car with the battery connected without problem one.
Probally a better idea to disconnect. Don't know if I will though. KT
'74 914-6 2.6 SS #746 '01 Boxster |
Senior Member
What if one or two of them are knocked out by welding every so often? The "charging" light is connected to ONE diode only I believe, so until that specific diode is not working you have no idea how many you have in the system working. When that one diode fails then the charging light comes on and tells you you have a problem. Its cheap insurance to disconnect the battery and in our cars pull the "14 pin connector" in the back to isolate the electrical systems when welding.
I can remember my dad and uncle disconnecting to battery before doing some farmer welding on the combine.
Would a generator sustain damage if left connected? Jim
down to jap bikes that run and a dead Norton |
Cheap insurance, but I have a hard time that this has ever happened under normal circumstances.
Alexander '75 911S Targa '86 951 SOLD |
We had made the mistake of not disconnecting the battery before welding on 2 vehicles in our body shop, once burned out a distributor and 2nd time an ECU...Learned the hard way...
1985 944 N/A 1992 Formula Firebird (sold) 1997 Sebring LXI 1998 Ford Expedition 1983 944 (parted out) 1979 924 Turbo (sold) |
Senior Member
Generators are not as sensative as alternators. Pretty simple to tell the truth inside. Still I would disconnect the system before welding.
JW Apostate
I'll disconnect from now on.
Thanks KT
You do not have permissi
A lot of powertrain/body computers operate at 9 volts and don't last long being exposed to 14V+ directly from the alternator. A welding machine puts out much more than that.
Meanwhile other things are still happening. |
Senior Member
