notfarnow's Avatar
Welding question
The rear sway bar mount broke off my dad's car, and he brought it over to have it fixed.
After dropping the sway bar, I had a guy down the road MIG weld the mount.
He insisted that we disconnect the battery before he welds. He said that MIG welding could damage electrical components in the car.
Makes sense, and I was glad to play it safe, but I had never heard of that before. Was he being overly cautious, or can MIG welding (or other types) actually damage electrical components?
'03 Carrera 4s
+ a whole bunch of boats
Old 07-20-2007, 11:26 AM
Senior Member
He is correct. The diodes in the alternator can be damaged by welders. Good call on his part.
Old 07-20-2007, 11:53 AM
Certified Pre-Owned
BGCarrera32's Avatar
In the basic sense MIG, TIG, and stick are a localized eletrical short circuit to heat the metal to melting temp for welding. Isolating a direct ground path back to the welder by disconnecting the battery is a wise move.
'84 Carrera Coupe
Old 07-20-2007, 12:12 PM
notfarnow's Avatar
Good to know, thanks!
'03 Carrera 4s
Old 07-20-2007, 12:15 PM
JW Apostate
trekkor's Avatar
On the flip side, I've done close to 20 hours of welding on my car with the battery connected without problem one.
Probally a better idea to disconnect. Don't know if I will though.
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 07-20-2007, 12:33 PM
Senior Member
KT
How many diodes are in the alternator? 6-8 I believe?
What if one or two of them are knocked out by welding every so often? The "charging" light is connected to ONE diode only I believe, so until that specific diode is not working you have no idea how many you have in the system working. When that one diode fails then the charging light comes on and tells you you have a problem.
Its cheap insurance to disconnect the battery and in our cars pull the "14 pin connector" in the back to isolate the electrical systems when welding.
Old 07-20-2007, 04:10 PM
I can remember my dad and uncle disconnecting to battery before doing some farmer welding on the combine.
Would a generator sustain damage if left connected?
Jim
down to jap bikes that run and a dead Norton
Old 07-20-2007, 04:16 PM
sketchers356's Avatar
Cheap insurance, but I have a hard time that this has ever happened under normal circumstances.
Alexander
'75 911S Targa
'86 951 SOLD
Old 07-20-2007, 05:44 PM
Send a message via Yahoo to bobp53916
We had made the mistake of not disconnecting the battery before welding on 2 vehicles in our body shop, once burned out a distributor and 2nd time an ECU...Learned the hard way...
1985 944 N/A
1992 Formula Firebird (sold)
1997 Sebring LXI
1998 Ford Expedition
1983 944 (parted out) 1979 924 Turbo (sold)
Old 07-20-2007, 09:10 PM
Senior Member
Jim
Jim,
Generators are not as sensative as alternators. Pretty simple to tell the truth inside. Still I would disconnect the system before welding.
Old 07-20-2007, 09:57 PM
JW Apostate
trekkor's Avatar
I'll disconnect from now on.
KT
'01 Boxster
Old 07-20-2007, 10:02 PM
Stand corrected.
Alexander
'75 911S Targa
'86 951 SOLD
Old 07-21-2007, 07:55 AM
You do not have permissi
john70t's Avatar
A lot of powertrain/body computers operate at 9 volts and don't last long being exposed to 14V+ directly from the alternator. A welding machine puts out much more than that.
Old 07-21-2007, 08:11 AM
Senior Member
As I have been told, its not the amount of volts as much as the spike of the current each time the spark is struck between the torch and frame of the car. Also if your grounds are not good then it backfeeds through all sorts of things, doing wonders to electrical components.
Old 07-21-2007, 08:32 AM
