durn for'ner
Thanks for trying, Lube !
![]() I will give you the typical doctorīs response: Thatīs interesting in theory. Come back in about twenty years when enough statistically significant work has concluded that the assumption lacked validity and Iīll buy you a beer. However, I very much believe that within the next 50-100 years we will have discovered how much different a world we have created during the last century in terms of the impact on living organisms. Organisms that were singled out in the gene pool race according to environmental circumstanses hundreds of thousands years ago. Our biology is not cut out for all the electro magnetic energy that surround us. There will be a price to pay and the Environmentalists are on to it, so we better drive our old petrol Porsches as long as we can.
Markus Resident Fluffer Carrera '85 |
Senior Member
Move away from the coffee machine. You have gone over the limit... a while ago!
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
canna change law physics
Lube,
This is a well known phenomenum. In Amateur Radio, you have to be careful in the 23cm and 13cm bands because it can be absorbed by the optic nerve. These are about 1.2-1.3 GHz and 2.3-2.4 GHz And just what band is used by WiFi routers?
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Banned
I wonder if this all has something to do with the odd condition known as "flicker vertigo".
FV is a physical nervous system response that is triggered by flashing lights and can lead to convusions in some people. The typical frequency that triggers this is about 25 flashes per second. Single-engine aircraft have crashed when their pilots encountered this on final approach. Landing into the setting sun, with the propellor turning about 1500 rpm, aircraft have simply rolled over and spun into the ground. In a few cases, a second pilot in the aircraft saved the plane when the PIC went into convulsions, so it doesn't affect everyone. hmm... |
Slumlord
Evolved
When younger, I used to get erections riding in some cars?
Was that what the Beach Boys song was really about?
Don't fear the reaper. |
It was a retorical question. 2.4 GHZ is used by WiFi routers.
Sultan of Sawzall
Gruppe B #319 2 '86 911 Carrera coupes (red & white) '66 Corsa convertible 140/4(red) '66 Monza coupe 110/PG(white) '95 993 cabriolet (wife's) |
Evolved
QUOTE: "Which one? "Wax my woodie"?"
_______________ Nope. "Good Vibrations!"
Masraum,
I’d take a guess it is the 1,000-1,200 cpm band as that’s the prop rpm range. Interesting that the engineers said it wasn’t happening until forced to sit in certain locations in line with the props. S/F, FOG |
Control Group
You should perhaps do a little reading on neurology. It would probably be easier to study this on a more priomitive system than mammals, sea slug would be a very good choice for a lot of reasons, ridiculously large neurons, real simple animal.
It has been a long time since I took any physiology, but there are channels in the cell membranes that either block or allow the passage of ions, K+, Na+, Ca++. A local anesthetic works by blocking these channels, strips the insulation off the wire so to speak. Impulse is there, but is not able to propagate along the neurons. Interesting thing is that folks with MS or similar neuromuscular diseases tend to do better in cooler weather. I have always felt that had something to do with electrical resistance, because your nervous system is wired with bioelectrical hardware. I seem to remember a study relating proximity of your home to High Tension electric lines and Neurologic tumors, also read a few things about the cell phone/brain tumor thing. The cell phone deal is largely eliminated by using an earphone, rather than holding it to the side of your melon.
She was the kindest person I ever met |
A Man of Wealth and Taste
I always told Mother that sitting in front of the TV was going to fk her up... But she would always retort, "What kind of New Age psycho babble are you dreaming up now, the next thing you will be promoting are crystals and I suppose you got informed by the Shopping Channel. ..."
Copyright "Some Observer" |
