Double Trouble
Shot this group today @ 100yrds.
Sighting in my Browning 25-06 A bolt today and shot this group. Think I'll send a few groundhogs to heaven later.
I used to be addicted to the hokey pokey..........but I turned myself around.. 75 914 1.8 2010 Cayenne base |
Looks like a lot of vertical stringing. That's gonna make it hard to hit ground hogs much farther away than that, unless they stand straight up for you.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
Double Trouble
Suggestions? You have my respect here Jeff, as you know I just started into rifles after a life of shotguns. Actually that is two groups. I was dialing in on the top 3 and the 3 that are in the 1 in. are the three shot results.
Oh, well then, I don't see a problem at all. As two seperate groups they look pretty darn good.
Just one suggestion; I would stick with the zero established in your upper group. It looks like 1.5"-2" high or so, which is an excellent 100 yard zero for any high velocity rifle like the .25-'06. That would allow you to pretty much hold right on a hog out to almost 300 yards. So which A-Bolt do you have? Standard barrel, heavy barrel, 'glass stock, wood stock, etc. What was the ammo?
Double Trouble
I will use your advice and thanks. It is the Medallion model 24" standard, non BOSS barrel. Wood stock. I was using Winchester factory varmint 90 grain expanding point loads.
Double Trouble
Model
A-Bolt Medallion Item Number 035002223 Caliber 25-06 Rem. Action Type Long Action Magazine Capacity 4 Barrel Length 24" Nominal Overall Length 44 3/4" Nominal Length of Pull 13 5/8" Nominal Drop at Comb 5/8" Nominal Drop at Heel 1/2" Nominal Weight 6 lbs. 14 oz. Rate of Twist 1 turn in 10 " Metal Finish Blued Wood Finish Gloss Finish Stock / Grip Walnut U.S. Suggested Retail
A Man of Wealth and Taste
Speaking of 25/06s. It was a caliber developed as a "wildcat" cartridge by A O Neidner back in the 1920s. It is basically a necked down 30/06.
AND..here is a custom target rifle in 25/06 by A O Neidner. It is built on a Springfield 1903 action and features a stock by Thomas Shellhammer. ![]() ![]()
Copyright "Some Observer" |
Evolved
Vertical stringing = watch your breathing!
Set ...breath ...let 'half' out ...hold ...squeeze!
Don't fear the reaper. Last edited by Mo_Gearhead; 11-22-2007 at 07:17 AM.. |
Registered abUser
yeah, aim for their nuts and you should take their heads off
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
