LOL!!
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
Banned
KE=1/2 M*V^2, Inelastic collisions. Energy must be conserved. Figure it out.
Think billiard balls, no english. Ball that is not moving has 0 KE as V=0 Energy is conserved, therefore all KE is transfered to 2nd ball leaving the initial ball with 0 KE, ie no longer moving. The velocity of the lighter ball will be = 1.41 x the velocity of the heavy ball (the sqrt of 2 more precisely) Want to check it out. Figure the KE of the 20 pound ball, then assume a velocity of 1.41 times that velocity for the 10 pound ball. The KE's are equal. Energy is conserved. QED Now for a difficult question. Why do you launder a wash cloth? ITs clean, you use soap and water to use it. Why doesn't the soap and water clean the wash cloth? Just wondering. Then theres the towel. Its clean, your clean, just water on you. You wipe down. Yet you still have to launder it!! WHY? I am sitting here, waiting to wipe my butt, just wondering, just wondering. Last edited by snowman; 11-29-2007 at 10:55 PM.. |
I'll use caps for mass and Velocity, so the subscripts, i and f for initial and final and 1 and 2 for the two objects make more sense.
M1V1i + M2V2i = M1V1f + M2V2f and 1/2 M1V1i^2 + 1/2 M2V2i^2 = 1/2 M1V1f^2 + 1/2 M2V2f^2 What it all comes down to is V1i + V1f = V2i + V2f or V1i - V2i = -(V1f - V2f) excerpt from my college physics book concerning elastic collisions. Physics for Scientists & Engineers 2nd ed, Serway Quote:
so V1f = 5/15 * 10 or 3.333mph Eq 9.23 says that V2f equals double the mass of particle 1 divided by the sum of the masses times particle 1's initial velocity. so V2f = 20/15 * 10 or 13.333mph Based on the math in the first two equations, I get different answers. I'm guessing that the difference between 10# and 5# is not enough to use the second set of equations. Here are the results with the first set of equations. The one thing that seems odd to me is the final speed of the second particle. I'd expect it to be higher. 10*10 + 5*0 = 10*V1f + 5*V2f .5*10*10^2 + .5*5*0^2 = .5*10*V1f^2 + .5*5*V2f^2 so V1f = 10 - .5*V2f -- substituting that into the second equation we get .5*10*100 + 0 = .5*10*(10 - .5*V2f)^2 + .5*5*V2f^2 when I solve, I get that V2f = 0 or 1.333.... since the weights aren't equal, it's not 0, then plugging 1.333 back into the first equation I get V1f = 9.3333 So part of that seems correct. The speed of the first ball hasn't changed by much since the second ball is lighter. So it only slows from 10 -->9.333..., but I'd expect the second ball to be going faster. So I'm not sure what, if anything I did wrong. so, after, the 10 ball would be moving at 9.333 and the 5 would be going 1.333 Maybe I got the answers backwards. Maybe the masses are close enough that the first ball almost stops and the second ball is going almost as fast as the first.
Banned
Only problem here is that the heavy particle is NOT much larger than the light particle. Much heavier imply s a factor of at least 10. In your case likely a factor of 1000 or more. Also the collision is not totally inelastic in your case, because energy MUST be conserved. The lighter ball MUST end up going faster than the heavy ball. Your calcs are probably what a real item would do (elastic}, but we are dealing with ideal (inelastic) balls here.
Anyone can do the math, its the setup that separates the men from the boys. Last edited by snowman; 11-29-2007 at 11:14 PM.. |
For this to work, the balls have to be the same size, like pool balls, even though the weights are different.
So the contact is square on. |
I thought the balls were in space?? But yes, they have to hit square..
Custom User Title
A few things here-
#1- I just got back to this thread, so I am going to try out the math and make it work. #2- Yes, in my scenario, the objects are hitting perfectly square. #3- An answer to the question about washing towels. In college, I decided to not wash my towels for this very reason- I was clean from the shower, so what would the point be in washing the towel? This proved to be fine for awhile. But about 2 months in, the towels start to have an odor, and it eventually gets pretty foul. They do in fact get dirty, and its from dead skin cells, slow growing mold, and little amounts of dirt that you miss when you shower. Washing towels after every use is stupid, but once a week or so is reasonable. Never washing them makes them smell bad. I know this for a fact. |
Want to test the worst case scenario. Wash a load of laundry, but leave it in the washing machine for several days without drying the wet stuff. It'll smell horrible, and it's just been washed, hell, it's still sitting in the washing machine.
abit off center
You take off to a distant planet at twice the speed of light, you land, get out and set up a telescope, can you see yourself coming?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Seldom Seen Member
My cat's name is Mittens.
Why do things that happen to white trash always happen to me? Got nachos? |
Seldom Seen Member
This is my all time favorite answer to a physics question that I wish I used back in school:
least common denominator
How much is a Zerio?
![]() If lesbian #1 is traveling at 10 Mph and hits lesbian #2 who is traveling in the same direction at 15 Mph what speed are lesbian #1 and #2 traveling after the collision?
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. Last edited by scottmandue; 11-30-2007 at 03:26 PM.. |
Dog-faced pony soldier
You're ignoring the effects of gravitational attraction between the two masses.
Also relativity and some ***** to do with quarks. And elves.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
When I re-did the math I got the same thing that Steve/sjf911 got in his simple, short post Quote:
before collision -- mv + mv = mv + mv -- after collision -- momentum and before collision -- 1/2 mv^2 + 1/2 mv^2 = 1/2 mv^2 + 1/2 mv^2 -- after collision -- KE so, the big ball would be going 3.333 mph after the collision and the small ball would be going 13.333 mph after the collision. Not really quite double the speed of the big one.
Banned
I don't think so.
