Guest
Posts: n/a
Hal No, I'm on my home dsl connection. I'm on Office 2003. |
I am certainly not an IT guy (or really a PC guy for that matter) but -
The HD you are now using as a removable drive presumably was the only drive in the laptop and still has the OS and system files on it. Is it possible that the PC you now have the removable drive hooked up to cannot see the 'hidden' system / application data files on the removable drive as they would conflict? Is it possible to make the removable drive "L" in this case the start-up disk to see if you can get the Documents and Settings folder to be visible? If you go to My Computer on the PC you are working on and follow the steps, can you find the Outlook Data file using the procedure shown? What is in the Documents folder under the "L" drive, is this your actual documents folder? |
Okay, what is the source of your email? Hotmail, AOL, etc? And Cached Mode is also available with Outlook 2003, are you using it? If so try a search for an OST file. That can be converted to a PST file and imported.
'17 Cayenne |
Semper drive!
Good call on the .OST file, Hal. That's where I would have gone next. But, since Mark isn't connecting to an Exchange Server, it may not be there either.
Randy
84 944 - Alpine White 86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )One Marine's View Igitur qui desiderat pacem, praeparet bellum |
Guest
Posts: n/a
I'm connected to sbcglobal via pop. Don't know anything about cached mode. I'll search for ost
I am trying to figure out what is happening. The email is either on a server (Exchange/POP3/IMAP) or on the hard drive as a PST/OST file. Randy, can you think of some other option?
'17 Cayenne |
Mark, maybe we'll get lucky. Cached Mode is on by default.
'17 Cayenne |
Guest
Posts: n/a
No luck with ost. Pretty sure emails are not cached on a server. I can view fresh emails on via sbcglobal webmail, but as soon as I fire up outlook, it downloads onto my pc.
Semper drive!
If the e-mails are still being stored on the server at SBC, one thing Mark could try would be to configure Outlook Express to access those e-mails. Before connecting and actually downloading the e-mails, he'll want to go into the account settings and select the option to leave the e-mails on the server after being downloaded. that way he'll still have access to them from another computer.
Or, something easier...Mark, can you log into your e-mail on the SBC website and access them there? Try doing that before you do anything with Outlook Express. Randy
Guest
Posts: n/a
OK, My eyes are crossed. Gotta hit the hay for tonight. Any other ideas you guys come up with, I'll try tomorrow. Thanks very much for the help. M |
You are positive that you were last using Outlook and not Outlook Express?
As for line: L:\Users\MWilson\Local Settings\Application Data\Microsoft\Outlook Why no "Documents and Settings" directory? What's the Laptop OS - Vista?
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Mark, try searching for "outlook". I'd expect you to get 2-4 hits that are directories. In those hits should be the default .pst file.
Also, you can try searching for "local settings" which should then contain a folder for "Application data" then "microsoft" then "outlook". In every XP system that I've ever seen, the "C:\" drive has a folder called "documents and settings" which contains a couple of folders for the various usernames associated with the system. In the folders for the various users, most user data (like a pst) is contained in the folder that I mention above. I've never seen an installation like yours where there doesn't seem to be a "documents and settings" but there is a "users". I just don't know. That's weird.
Maybe look here
![]() I also found this online Quote:
http://www.slipstick.com/config/backup.asp
Semper drive!
Dave, Looking at the screenshots Mark posted, it certainly looks like XP. I even tried googling Outlook running on XP Home Edition, thinking maybe "Home" used a different file structure, but that doesn't seem to be the case. Like Steve mentions, I've never seen a structure like that...one that doesn't utilize the "Documents and Settings" folders. Steve, doing a search for "Outlook.*" is a good call. Randy
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD Last edited by slodave; 12-29-2007 at 11:48 PM.. |
Mark:
Try the following: 1-Open WINDOWS EXPLORER 2-Find the drive which you think has your Outlook file. 3-Do a search for all files with the extension *.pst 4-You should find a fairly large file called outlook.pst. That is your outlook data file. 5-Write down the full address. 6-Open Outlook 7-Under File -> Open => Click on "Outlook Data file" 8-A file seletion menu will open. Browse tot he .pst file you found earlier and click on this. 9-In your "Navigation Plane" you will see a new set of folders under the "standard mail" filders. This is the file you just opened. Good luck.
Guest
Posts: n/a
I knew it was simple and I was just too tired last night to find it. Did the search for "Outlook" and results came back with no .pst folder. In the search pane, at the bottom, there was an option to search all files and folders, so some of them were still hidden on the "L" drive even though I had toggled "show all files and folders" to on. This is the search screen that came back. Just shows that you guys were right back at the first of the thread telling me to find the pst. I have it importing now.
Thanks to all for the help.
Guest
Posts: n/a
BTW - for reference, the laptop was running Vista home and desktop is an XP machine.
Cool, glad that you found it.
Vista, that explains the different directory structure. Thanks for the update.
Semper drive!
Outstanding work, Mark! Glad you got it all sorted out.
+1 on the Vista comment by Steve. I swear, MS changed so many things around, for no apparent reason, when they came out with Vista. ![]() Anyway, glad you got it working. Good on ya!!! Randy
