carreradpt's Avatar
Auto Electrics for dummies
Can anyone recommend a book dealing with auto electrics that is pretty basic and can get me figuring out where to start when I need to troubleshoot? I have a couple of little issues that I would like to get working on. Thanks, DT
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 8's, Steve W chip
Kuehl AC and fresh top end
Old 12-30-2007, 12:12 PM
Describe the issues and the kind of car. Some of us here might be able to help.
Bob S. former owner of a 1984 silver 944
Old 12-30-2007, 12:14 PM
Cars & Coffee Killer
legion's Avatar
Haynes manual?
5 liters of VVT fury now
-Chris
Old 12-30-2007, 12:15 PM
carreradpt's Avatar
My left turn signal and left tail light are inop. When I pull my light switch to the first stop the fuse blows. I have pulled the light covers and checked the areas for obvious shorts but I do not know where to start with the troubleshooting. What works best for me is to have a guide to say start here, do this. I have a pretty good multitester. Just wished I knew what an ohm is and what I am checking with it.
Dan T
'85 Carrera
Old 12-30-2007, 12:21 PM
Check all the lights.. pull the bulbs out and try again. You may have a broken dual filament (stop/tail) light bulb which is back feeding. Try also disconnecting the light unit wire harness from the body harness (it's inside the engine compartment)
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 12-30-2007, 01:17 PM
carreradpt's Avatar
Britwrench, where is the light unit harness in the engine compt?
Dan T
'85 Carrera
Old 12-30-2007, 04:26 PM
On the extreme end of the inner engine panel (by the rear fuse box) is a round socket set into the metal, that is the haness plug from the lights, the body wire harness plugs into it.
I would remove all the bulbs first and check them before doing anything else.
Old 12-30-2007, 04:36 PM
A short finder may be your best friend.... http://www.eastwoodco.com/jump.jsp?itemID=1378&itemType=PRODUCT&cm_mmc=PMD_SE-_-Google-_-Electrical_
Warren & Ron, may you rest in Peace.
Old 12-30-2007, 05:48 PM
D idn't E arn I t
RANDY P's Avatar
disconnect all the lights on that side, then test - keep adding one bulb at a time until it blows fuse. if blown fuse right away before the 1st bulb disconnect the harness, then plug 'em back in one at a time and repeat process.
Clean the grounds as well, if they have resistance then the voltage requirements will go up overloading the fuse.
AOC/Hogg 2028
Old 12-30-2007, 08:14 PM
HP and Peterson sell nice hot rod store basic electric books for around $20/ea. Marine stores sell others that are also very good at offering a fuller look at car electrics. Good eventual entrainment is small aircraft elec books. And once you start with ECM troubleshooting and trick multiplex systems a very high speed scope might become necessary?
those short finders are a good tool imo.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-30-2007, 08:28 PM
