Help with OBD diagnostics
Am I interpreting this right? It is a 4 cyl so there is no bank 2
  • Long Term Fuel Trim Bank One: 17.94 % ...... It is adding much more fuel than it thinks it should
  • System Too Lean .... Intake air leak?
  • Absolute Throttle Position: 19 % Engine RPM: 753 r/min ........ HUH?
Freeze Frame data
MIL:
On
Diagnostic Trouble Codes
P0171
System Too Lean (Bank 1)
Freeze Frame (Frame 0) for DTC P0171
19 %
Air Flow Rate From Mass Air Flow Sensor:
0.46 lb/min
Calculated Load:
20 %
Coolant Temperature:
196 F
Engine RPM:
753 r/min
Fuel System Status Bank One:
Closed Loop
Fuel System Status Bank Two:
Not Reported
Ignition Timing Advance for #1:
7.0 deg
Intake Air Temperature:
46 F
Intake Manifold Absolute Pressure:
8.6 in.hg
17.94 %
Short Term Fuel Trim Bank One:
-1.56 %
Rick
88 Cab
Old 01-11-2008, 07:25 PM
lm6y's Avatar
What kind of car?
"Generally" a lean condition is a bad o2 sensor, or a fuel pump. Is the scanner not giving you an o2 sensor reading for the freeze frame data ?
It could be a vacuum leak too, as you said.
Brent
Early85 944
LM6Y Paint Code
Old 01-11-2008, 09:17 PM
It is a Chevy Colorado
Inspection/Maintenance Monitors Status
Name
Status
Misfire Monitoring
Complete
Fuel System Monitoring
Complete
Comprehensive Component Monitoring
Complete
Catalyst Monitoring
Complete
Heated Catalyst Monitoring
Not Supported
Evaporative System Monitoring
Complete
Secondary Air System Monitoring
Not Supported
A/C System Refrigerant Monitoring
Not Supported
Oxygen Sensor Monitoring
Complete
Oxygen Sensor Heater Monitoring
Complete
EGR System Monitoring
Not Supported
Monitored Test Results (Mode $06)
Test ID
($05) Oxygen Sensor Monitoring
Value
425.000
Min
0.000
Max
2048.000
Units
mV
Test Description
($01) Rich to Lean Sensor Threshold Voltage - Bank 1 Sensor 1
Test ID
Value
425.000
Min
0.000
Max
2048.000
Units
mV
Test Description
($02) Lean to Rich Sensor Threshold Voltage - Bank 1 Sensor 1
Test ID
Value
350.000
Min
0.000
Max
2048.000
Units
mV
Test Description
($03) Low Sensor Voltage for Switch Time Calculation - Bank 1 Sensor 1
Test ID
Value
650.000
Min
0.000
Max
2048.000
Units
mV
Test Description
($04) High Sensor Voltage for Switch Time Calculation - Bank 1 Sensor 1
Test ID
Value
39.375
Min
0.000
Max
1024.000
Units
msec
Test Description
($05) Rich to Lean Sensor Switch Time - Bank 1 Sensor 1
Test ID
Value
32.484
Min
0.000
Max
1024.000
Units
msec
Test Description
($06) Lean to Rich Sensor Switch Time - Bank 1 Sensor 1
Test ID
Value
249.000
Min
141.000
Max
0.000
Units
Switches
Test Description
($07) Rich to Lean Switches - Bank 1 Sensor 1
Test ID
Value
253.000
Min
141.000
Max
0.000
Units
Switches
Test Description
($08) Lean to Rich Switches - Bank 1 Sensor 1
Test ID
($0A) Evaporative System Monitor 0020" Leak
Value
0.200
Min
0.100
Max
6553.500
Units
sec
Test Description
($01) EVPD Canister Vent Restriction Test 1
Test ID
Value
5.001
Min
0.000
Max
31.999
Units
inH20
Test Description
($42) Engine Off Natural Vacuum Tests
Test ID
Value
9.110
Min
0.000
Max
65.535
Units
Liters
Test Description
($13) EVAP Vacuum Pressure Decay (Weak Vacuum) Test
Test ID
Value
0.000
Min
0.000
Max
0.000
Units
Unitless
Test Description
($04) Undocumented CID
Test ID
Value
600.000
Min
600.000
Max
0.000
Units
Unitless
Test Description
($07) Undocumented CID
Test ID
Value
0.000
Min
-3276.800
Max
3276.700
Units
inH20
Test Description
($48) EVPD Purge Vacuum Fail Test
Test ID
Value
0.000
Min
0.100
Max
255.996
Units
Ratio
Test Description
($0A) EONV .020" Small Leak Test
Test ID
Value
0.051
Min
0.100
Max
255.996
Units
Ratio
Test Description
($0B) EONV Vacuum Rezero Test
Test ID
($0C) Catalyst Efficiency Idle Monitor
Value
-6.991
Min
-32.768
Max
32.767
Units
sec
Test Description
($60) Idle Catalyst Efficiency Test - Bank 1
Test ID
($0E) Oxygen Sensor Heater Monitoring
Value
0.000
Min
0.000
Max
45.000
Units
Samples
Test Description
($11) Oxygen Sensor Heater Current Samples Outside Threshold (X/Y Samples Test) - Bank 1 Sensor 1
Test ID
Value
0.000
Min
0.000
Max
45.000
Units
Samples
Test Description
($12) Oxygen Sensor Heater Current Samples Outside Threshold (X/Y Samples Test) - Bank 1 Sensor 2
Rick
88 Cab
Old 01-11-2008, 10:01 PM
djmcmath's Avatar
Too lean could very well be a vacuum leak post-MAF. Try the old carb cleaner trick to see if you can identify anything. If that fails, it isn't necessarily not a vacuum leak, it could still be one that's hard to find. Fuel pump starting to fail would cause fuel pressure to be less than calculated, depending on where your system senses pressure at. Oxygen sensors typically tell you when they're bad, don't they? I know that mine gave "out of range" errors when they started going out.
'86 911 (RIP March '05)
'17 Subaru CrossTrek
'99 911 (Adopt an unloved 996 from your local shelter today!)
Old 01-12-2008, 06:22 AM
