Vafri
It's an old cliche' but the three most unuseful things in aviation are fuel in the truck, runway behind you and altitude above you.
I can fly fast and low, but it's mission dependent. I can fly to min on an NDB, land in the dirt w/ NVG and have landed on a flattop I've never seen. But Uncle Sugar has made me do it. In general aviation I'd use the three rules, plus check wx, alternate routes, etc...without hesitation EVERY time, unless I were only flying around the patch doing T&G in the weather I could see with my own two eyes. |
MAGA
+1 for my Piper Pacer (autofuel STC) and my Minimax (Rotax 2-stroke). I have a local farm fuel service deliver NON ethanol containing car gas to me on a regular basis. It typically costs 25 cents a gallon or so more than the going price at the gas station, but it is convenient and it is much cheaper than filling up at the local airport. I have put around 500 hrs on my Pacer since I have owned it and compression at every annual has remained in the high 70's.
The plane I am building will have a Lycoming io-360 (200hp) on it and due to the higher compression, I will have to start buying AV gas again.....not looking forward to that. I nearly go into shock everytime I go on a long trip and have to fill up at an airport.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
can relate to fing...used to get a middle-of-the-night trip from tampa twice a month to leave tampa, fly to san juan, pick up a pair of guys and their heavy luggage, then fly non-stop in the winter to newark or teterboro across the bermuda triangle in a lear-35. when you took off, during climbout the fms would always predict a landing with 'negative fuel', then as you reached cruise, the numbers would gradually climb into the positive. so, you'd experiment with different winds, trying to decide to sacrifice rate of fuel burn for higher groundspeeds. as you sat there for hours over black water, you'd watch the groundspeed slowly decreasing, predicted landing fuel weight decreasing as well. it was a pain in the ass. we had a lear-36xr that could easily do the trip without any risk of not making destination. anyway, you always had an out..you could land in north carolina, or philly, but then you'd have to arrange ground transportation for your passengers to new york from there (company hated to see and no tip..lol). foryunately, i always managed to squeeze in, but i never enjoyed it. also, since our lear-36xr was not rvsm-certified, returning from western europe in the lower flight levels in winter, bucking 100+ knot headwinds meant deciding on whether to continue to gander, nova scotia or landing in iceland. you'd think these 'calls' would always be easy, but sometimes the decision would be so close and there was always a certain pressure to complete the planned flight. i made good decisions..i'm still here.
fwiw, i quit flying part 135 learjet freight, charter and air ambo to return to general aviation. i've been back being a full-time general aviation flight instructor for about a year..after having done it from 10-15 years ago roughly. i traded income for quality of life. i'm home every night now after years of being away for 1-3 weeks at a time on a regular basis..life on a pager where everything was unscheduled - when that thing 'rang', it meant be at the airport in 15'..and be ready to be wheels-up in 45'. the lifestyle sucked..but i do miss the lear. if some idiot high-net worth individual would ever buy an old 20-series learjet (nobody with any sense would - they're turbojets and burn roughly 30% more fuel than the later turbofans so not very practical, but damn they're funnnn! and tough - eight spars per wing)..anyway, i'd probably quit instructing to going back to pic on one of those. joe, i think you used to slog freight around in these , too? maybe about a decade before me? i started around the mid-90's in them. haven't flown one in several years..would kick my ass initially, i'm sure. i couldfly 'em 'in the day', though.
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
In a jet (well the larger and more modern jets) you rarely "top off" the tanks on shorter trips. In a larger jet you can carry large amounts of fuel, and if you are going shorter distances it just doesn't make sense to carry all the extra weight. If you were flying 400 miles in a Lear 60, it would take less than an hour, but if you topped the tanks off you would be carrying an extra 5,500 pounds of fuel. This means you would be using more fuel, just to carry the weight of the extra fuel. Not very efficient. As bigchillcar and some others are pointing out, for a good portion of a long flight (sometimes over half) you technically do not have enough fuel to make it to your destination. Then as you burn fuel off, you get lighter and it takes less power for the same speed and you "make fuel". Our "box" says we'll run out of gas about halfway to our destination, then we usually end up landing at our destination with an extra 1 hr or more of fuel. At altitude winds and temperature plays an extremely important role. 1 or 2 degrees of change is noticeable in performance at altitude. At lower altitudes we burn about 4000 pounds an our or more. At altitude it's more like 1200. I've never flown a 20 series like bigchillcar, but I've heard they burned as much fuel idling on the ground than they did at cruise! Maybe bigchillcar can set us straight on that.
'82 911 SC |
a 20-series lear at gross will pull hard all the way up to fl410..the bypass-engine turbofan versions, like the lear-35 couldn't make it to the top at gross weight.
20-series lear in cruise will see around 1,500 lbs/hr....but boy, did a few vfr ferry permit flights below fl180 with burn rates near 3,000 lbs./hr! at idle?? a 20-series is burning a little more than 2,000 lbs./hr...so you're right..they burn less at cruise than at idle.
Banned
Me: Type rated in the B727 and 747 Classic. Significant time in both as a Captain.
YES, you can just hop in your personal airplane and go. -The best flight I have ever done was when I took the other in my 928 down to the Florida keys. We rode US-1 down to Marathon, where we passed the airport. "I bet this is a beautiful place from the air" she said. That was all it took. Tire-smoking seconds later, my German small-block V8 was rumbling in the parking lot of the FBO in Marathon. I took her on two flights- one while I was being "checked out to rent", and the other on a one hour trip from Marathon down to Key West and back. It was beautiful, and we still talk about it! The best thing you can ever do is take your girl flying. I'm not going to go into any detail about how good the sex was that night.... N! |
Insert Tag Line HERE.....
Some guys i fly with now used to fly the L20, and I cant think of ONE of those guys who didnt have a near death experience due to some sort malfunction or more like a nuance of that plane.
Banned
Here's a technical specification that you should memorize:
PA-28-161. That is the Piper Cherokee Warrior powered by the 160 hp 0-320. This airplane will treat you well, and it won't disapoint you. And every flight instructor in existance is checked out in this airplane! N! |
Dog-faced pony soldier
+1.
The variations on that platform are all pretty good - the Cherokee 180 (PA28-181), the Arrow (retractable, complex), Seminole (multi-engine), etc. All very good, solid airplanes. My original solo was in a PA28-161. I have a soft spot in my heart for them. Very good, solid, stable platforms. Cessna makes a good airplane too, but I've just always liked the Piper design a bit better. Low-wings just LOOK more like airplanes, IMHO.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Non Compos Mentis
For local pleasure flights, I often don't decide which way I'm going to fly until taxiing out to the runway. The guy in the control tower wants to know which way I'll be departing, so I better decide before taking off.
My airplane carries well over four hours of fuel. I'll probably be back in an hour or two. But the pre-flight inspection is just as thorough as when I'm going to cross the Rocky Mountains. |
count me in with that company..
i just really loved it..never got a chance to fly one of course.and you're right about the warrior..i spend a great deal of time each week giving instrument instruction/ipc's in warriors/cherokees/arrows. they're my favorite 'trainer platform' for doing instrument training. although it would be nice to fly 'just one' with decent gyros and radios..
Senior Member
We just brought the bird back to CONUS and both of us smiled when we first heard an American voice on the radio approaching "feet dry" in point.... you guys flying over here have it very good.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Senior Member
Any airplane can bite you if not treated right, but they are far safer than women...
as for ndb's...i still teach them every week. the students that i work with still fly old aircraft with really old radio stacks, so they're still there. in fact, i haven't had an opportunity to shoot a single gos approach all year! one of the guys has an old bendix 'manual tune' ndb that must be 40+ years old. ndb's are my fave..after the basic aircraft control by instrument reference is learned, i begin with them. if they can track ndb bearings, vor and ils orientation is a breeze...usually..
again, joe are you sure it was serial #9 you flew? i flew many hours in #9 and also #16. it's my understanding that there may be only one or two still flying older than #9..perhaps it was one of those?
Senior Member
http://www.airliners.net/search/photo.search?regsearch=N88B&distinct_entry=true
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB Last edited by Joeaksa; 01-22-2008 at 03:12 PM.. |
Banned
The "whale" is a great airplane to fly. I've learned that the bigger they are, the easier they are to fly, and the 747 flies great. It is easy if you are used to transport-catagory jets' decent profiles. You have to be careful with this airplane: Despite appearances, it is EVERY bit as maneuverable as a 727 or a Piper Seminole. The problem: There are four 13,000 pound engine/pylon assemblies on that wing, and if you really rack it over hard...you can actually throw one of them off. It is a little hard to land smooth, since there are four main gear trucks. It has one big vice however: It uses runway like you won't believe! Holy *****! My first takeoff in this thing was from rwy 32 up in Anchorage, and when we reached rotation speed...there was literally NO runway remaining! Same thing when landing. You land, you let the autobrakes do their thing...and the plane just goes on down the runway. "Hell-o! Wow...those red lights are coming up quick!" After you finally stop, you look back at the flight engineers' panel, and you can litterally watch the brake temperature gauges climb into the yellow and red bands... If I were going to buy a light airplane, I'd buy either a Warrior or one of the Hershey-bar wing Cherokees. They fly nice, and feel MUCH more solid than the Cessna 152 or 172. You're right though- finding an IFR PA-28 that has been maintained properly isn't that easy. N |
bet you and i would have had fun together flying an early lear..god i miss them. it's been so long now that when i walk up to the big lear cockpit poster on my wall and look at the switches and buttons..i have difficulty remembering what did what. you ever get a chance to 'ferry one' for some reason and are current, holler at me..i'm several years out of currency, but i'm sure i could handle being an sic again..daddy! 'ol ryan will easily defer to your currency and experience.
yeah, show me almost any piper warrior or cherokee tied down at most fbo's and i'll show you a single-axis a/p that doesn't work, a dg that precesses, compass that hasn't been swung in a decade..and radios? don't get me started down that path..
