kang's Avatar
Be sure you seal it after you clean it!
Downshift
Old 03-28-2008, 08:37 AM
Originally Posted by trekkor View Post
Just to be clear. It's sealer or colorant.
The grout needs to be stripped clean before either can be applied.
The colorant will not stick to sealer. Especially "511".
KT
The stuff I used was sealer AND colorant all in one. Worked great.
1957 Speedster, 1965 356SC, 1965 356SC Outlaw, 1972 911T, 1998 993 C2S, 2018 Targa 4 GTS, 2014 Cayenne S, 2016 Boxster Spyder, 2019 Tacoma
Old 03-28-2008, 09:44 AM
JW Apostate
trekkor's Avatar
I hear you. The point is, don't seal it first, then use the colorant.
Use one product.
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 03-28-2008, 07:16 PM
Right, makes sense. Let me ask you, now that I've done the grout, any harm in applying a penetrating sealer on the entire floor, to seal the tile also?
Old 03-29-2008, 05:22 AM
JW Apostate
trekkor's Avatar
Most tile is glazed and does not/will not recieve a sealer.
If the grout is RAW it will take a penetrating sealer.
If it has been colored ( epoxy color sealed ) I'd suspect it will resist new sealer or the color will be damaged by the solvent based sealer I suggested.
KT
'01 Boxster
Old 03-29-2008, 06:37 AM
