Be sure you seal it after you clean it!
Downshift |
The stuff I used was sealer AND colorant all in one. Worked great.
1957 Speedster, 1965 356SC, 1965 356SC Outlaw, 1972 911T, 1998 993 C2S, 2018 Targa 4 GTS, 2014 Cayenne S, 2016 Boxster Spyder, 2019 Tacoma |
JW Apostate
I hear you. The point is, don't seal it first, then use the colorant. Use one product. KT
'74 914-6 2.6 SS #746 '01 Boxster |
Right, makes sense. Let me ask you, now that I've done the grout, any harm in applying a penetrating sealer on the entire floor, to seal the tile also?
JW Apostate
Most tile is glazed and does not/will not recieve a sealer.
If the grout is RAW it will take a penetrating sealer. If it has been colored ( epoxy color sealed ) I'd suspect it will resist new sealer or the color will be damaged by the solvent based sealer I suggested. KT
Thread Tools | |
Rate This Thread | |
