Extend life for AA batteries
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
That's a whole lot of words for not much information. How does it work?
Air Medal or two
I so doubt this.............If anything I smell smoke
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
Kind of like spending $25 on a sharpener for your $1.99 disposable razor.
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
I sorta skimmed the article and it the premise of the device makes sense at first, until I gave it some consideration. Alkaline batteries seem to have a big voltage sag as it depleats, however that means any decently designed battery operated device should have built in powersupply, that basically does the same thing as this device. It might add 35cents to the price of the device.
If you add another switching power supply in series, you are actually losing capacity because of conversion inefficency ![]() If you look at this graph, no degreed engineer would design a device that has a low voltage cut off near 1.5 volts
84 930 18 Cayman GTS |
First gererator I've seen under $3.00....
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Just ignore alkaline batteries and choose Eneloop rechargables. 2x the price and 2000x the utility. The math just works.
http://www.amazon.com/Panasonic-BK-3MCCA8BA-Pre-Charged-Rechargeable-Batteries/dp/B00JHKSN5I/ref=sr_1_1/180-9388840-0877800?ie=UTF8&qid=1433435954&sr=8-1&keywords=eneloop+aa
2009 Cayman PDK With a few tweaks 2021 Cayman GTS 4.0L 2021 Macan (dog hauler) |
Information Junky
what aschen said. Alkaline batteries carry quite a bit of power(far better than most - on paper) yet many devices draw too fast or need a certain threshold voltage that Alkaline batteries can deliver for only a relatively short time. Leaving unused potential.
Thanks for the post, JYL. ...even if they are over promising, it's still cool stuff to read/consider.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Air Medal or two
How does it work, (in layman terms)
You send money to the batteriser people, and they buy nice things for themselves and their families
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
IF you look at my graph the area under the curve is the total energy available from the battery
If you have a device such as a remote control that will quit operating below 1.2v, you are throwing away a good portion of the available energy The idea is to put in a step up power supply that boosts the output voltage so the device can still function. DO to conservation of energy the device will draw more current from the battery when the voltage is low, but at least you are still using more of the capacity in super laymans terms, it lets you use all the ketup like liqui glide ![]() https://www.youtube.com/watch?v=djwahGRi5iE
Last time I used an alkaline battery in my gadgets I was wearing stonewashed jeans and an Ocean Pacific t-shirt.
Lithium Ion. I have a gadget that I depend on - and it is constantly on. With alkaline, I would have to replace the battery every 3 weeks. With Lithium, I go 3 months before I need to replace that battery. -Z-man.
2010 Cayman S - 12-2020 - 2014 MINI Cooper S Coupe - 05-17 - 05-21 1989 944S2 - 06-01 - 01-14 Carpe Viam. <>< |
Air Medal or two
LOL
OK thanx
Mine is more fundamental, but practically speaking I predict this thing could only work for the cheapest of chinese toys or super basic devices with no built in power conditioning (flashlights perhaps?)
Likely with Smoke, Mirrors and paid testimonials.
Alkaline are for tv remotes, kids toys, etc.
Its worth saying one more time explictly, while I don't think this thing works, its theory of operation has some basis in reality
Aschen build very expensive battery powered industrial tools which have very similar internal circuitry to optimize battery depletion
OK, I had someone explain how something like this could work. It is only useful in limited types of devices.
Lots of devices shut off when the voltage from the battery gets to 1.1 or 1.2. There is still energy in the battery, but the device can't use it. This gadget (or something similar) can act as a step-up transformer, taking low voltage, high current power and boosting it to higher voltage, lower current power. This will only be of benefit on devices that draw a small current but require a certain minimum voltage. Devices that are not voltage sensitive, like a flashlight, would not benefit. The basic explanation I got made an analogy with the coil in an old car engine. The spark plugs need 12000 volts to fire, but the battery only puts out 12. The battery has lots of energy stored, but the spark plugs can't use it. The coil steps up the voltage so the plug can fire. The spark plug only needs a trickle of energy out of the battery, but it needs it at a high voltage. So if you've got a device that requires a minimum of 1.2 volts and your battery is depleted down to putting out 1 volt, a step up transformer will raise the voltage to the minimum to run the device - for a while.
It is a switching powersupply which is sortof a modern equivalant of a regulated step up transformer one thing I just remembered is even my modern flashlight has a built in switching power supply. It can run off 3 or 4 c cells at the exact same intensity. It just lasts longer if you put in the extension battery. This concept definitely works, the problem is it is likely built into almost everything you own already
