Dept store Quartermaster
lendaddy's Avatar
"disk read error" :(
My laptop froze last night and now gives me the "disk read error" screen and will not boot XP. Is this usually terminal?
Cornpoppin' Pony Soldier
Old 05-28-2008, 04:19 AM
MRM MRM is online now
Sounds like the hard drive is failing. Is your laptop three years old? I think they have an internal clock that says self destruct at about three years.
MRM 1994 Carrera
Old 05-28-2008, 04:28 AM
id10t's Avatar
Probably terminal, but you may be able to get data off it.
Ever hear of the freezer trick? Take drive out, put in plastic bag, put in freezer. Wait a bit, plug in boot up and start copying...
Old 05-28-2008, 04:31 AM
lendaddy's Avatar
lol, yea it's about 4-1/2 years old.
Old 05-28-2008, 04:33 AM
lendaddy's Avatar
Thanks,
I may have to try that.
Old 05-28-2008, 04:34 AM
Did you get the memo?
onewhippedpuppy's Avatar
PC load letter.......what the f- does that mean?!
‘07 Mazda RX8-8
Old 05-28-2008, 04:39 AM
lendaddy's Avatar
Damn it feels good to be a gangsta
lendaddy's Avatar
The drive is in the freezer, and the wait begins.......
Old 05-28-2008, 05:23 AM
id10t's Avatar
Just remember to hook it up quick and avoid condensation...
Old 05-28-2008, 05:39 AM
The Unsettler
stomachmonkey's Avatar
Len,
Read errors can be several things.
If one occurs in the boot sector it can prevent the machine from starting, OS can't fully load.
If it occurs elsewhere you may not be able to copy the data from that section while everything else is fine.
The real key is do you you have a mechanical failure of the entire device or some bad/corrupt sector/blocks.
If it hangs in the same place everytime I would assume bad sector/blocks.
If you have another computer go out and get a cheap USB enclosure for a 2.5 drive, hook it up to another machine, your wifes Mac will work just fine, and copy your data off.
"I want my two dollars"
"Brandon Won"
Old 05-28-2008, 05:52 AM
lendaddy's Avatar
I have an enclosure here and I'll try it on my PC thanks
Old 05-28-2008, 05:56 AM
Senior Member
Hope this was a joke...
There is no timer in any computer as you mentioned that I know of and have been working with them or building them for over 30 years.
2013 Jag XF, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB
Old 05-28-2008, 06:57 AM
http://www.drivesolutions.com/
try this site !
Had same problem with my Compaq laptop.Took the chance to upgrade my harddrive
to a much better/faster/bigger drive. I did loose everything ! but I did get a much better
drive!
Good Luck.
Old 05-28-2008, 07:08 AM
Calm down Joe, I'm 99.99% sure he's joking. I have a 3 year old Gateway laptop that's still working well. Of course, I also had an HP laptop that was sent in for repair 3 times within one year, not to mention the broken keys that they didn't cover.
‘07 Mazda RX8-8
Old 05-28-2008, 07:12 AM
VincentVega's Avatar
Damn. I was .01% sure he was serious
Old 05-28-2008, 07:45 AM
Glad we're 100% sure of something.
‘07 Mazda RX8-8
Old 05-28-2008, 07:46 AM
abit off center
cgarr's Avatar
You need to try mounting your hard drive!
______________________
Craig
G2Performance
Old 05-28-2008, 08:39 AM
lendaddy's Avatar
I have it in an external enclosure and it's balking. I have it recognized on "My Computer" but I can't get into it.
Old 05-28-2008, 08:47 AM
madmmac's Avatar
Did you try booting in through safe mode?? Hit f8 while it boots.
madmmac AKA Mitch
1984 Factory Turbo Look
2006 4Runner
1998 TRD Supercharged 4Runner (Sleeper)
Old 05-28-2008, 08:51 AM
lendaddy's Avatar
Yea, it never gets to the windows screen where that works. I can F2 and get into the base setup (boot sequence, etc) but not windows.
Old 05-28-2008, 08:56 AM
