Free minder
Boat engine seized. What to do?
I wonder if anyone had this happen to them, and how they handled it:
Last fall, I paid by check the marina to winterize by boat motor (4.3L V6 OMC). They`re supposed to run antifreeze, spray the carb intakes with oil, and fill the spark plug holes with oil. This morning, I go to start the motor with a fully charged battery, and no way to make it turn. I tried to turn it by hand with a wrench in the crank pulley. It would not budge. Last season, I had no problem starting it after winterizing. Could this be hydraulic lock from the oil in the cylinders, in which case I should remove the spark plugs? Or, If the marina did not winterize properly, then it will be costly, and clearly their responsibility, but how to go about it? Thanks for any advice, Aurel |
Evolved
QUOTE: " ...and FILL the spark plug holes with oil."
__________ Are you serious? If they indeed FILLED the cylinders with oil (not just misted) you have 'hydraulic lock'. Pull spark plugs and crank engine to pump it out! _______________ I can't imagine a Certified Dealer/Marina doing that ...however if you insisted and some kid/mechanic took you at your word...?
Don't fear the reaper. Last edited by Mo_Gearhead; 05-31-2008 at 07:06 AM.. |
I'd pull the plugs and see if it will turn over then. I have a jet boat and it did the same thing. After I pulled the motor it spun free. It wound up being a siezed bearing in the lower unit (jet drive) I rebuilt it and havent had any trouble since. Keep us posted on what happens.
Free minder
I pulled the sparks plugs and I think the picture below speaks for itself. If they are corroded like that, chances are my cylinders and pistons are the same. A mist of oil in there sure would have prevented that.
![]() Then I spoke to grandson of the owner of the marina and showed him the plug, and he admitted that they fired the mechanic, who was a deadbeat stealing from them, now living on his truck. I guess I should be happy if my block isn`t cracked. To make it right, he said he will reimburse me the $850 fee I just paid to the marina, and he will speak to his grandpa who`s got lots of money (as anyone who pays deadbeat mechanics under the table would). Now, I have to get quotes for a rebuild of that motor, and if I play it right, I may end up with an overhauled motor and a free boating season (except for the gas) .Aurel |
Bandwidth AbUser
I hope they come through for you and make this right. It sucks to miss part of the season while they fix your engine. Now, you really out to be thinking about a sailboat instead of a stinkpot power boat. You could be out on the water right now.
Jim R. |
It appears that the motor is full of water. How could that happen? It almost seems intentional and I wouldn't hesitate to mention that.
It got full of water from sitting outside in the winter without being winterized properly. Sorry to hear about it. Let us know how it turns out.
MRM 1994 Carrera |
Parrothead member
Pull the plugs, try to crank it by hand. Like Milt said It look like the engine was filled with water. Thats an awful lot of corrosion for just not being fogged.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
least common denominator
I am no expert but if it is that corroded shouldn't he spray some breaking oil (PB blaster, liquid wrench) in there and let it soak in before trying to spin the engine?
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
Free minder
No way I can crank it by hand, even with a two ft breaker bar on my wrench. I wonder how water could have gotten inside the cylinders. There is a cover on the motor, and a cover on the boat. Only thing I can think of is a blown head gasket, but the motor was running fine before winterizing. I am going to let a pro handle it from now on anyways. Got enough on my plate with rebuildling my 3.0L SC motor...
Aurel |
Parrothead member
What kind of marine engine is it?
"O"man(are we in trouble)
no way did they winterize that engine, looks like they put it up, didn't even drain the block, cracked the block from being frozen and now you have water in at least in one cylinder and hyro lock.
Never should have happened, they didn't do shlt to that engine last fall. Good luck on getting that covered. |
$850 is a lot of money to winterize something. You can do it yourself and save a lot of $$. It's not that hard.
Here is a very comprehensive list...most mechanics don't do a thorough job (as you have found out): Winterizing your engine and drive. Winterizing your boats engine and drive is a lot of work. Not doing it or doing it improperly WILL be very expensive to fix , and that is also a lot of work.__________________ Last edited by billh1963; 05-31-2008 at 12:28 PM.. |
Free minder
4.3L OMC V6. The mech I spoke to says it is not worth rebuilding (or he doesn`t want to...) but putting in a new one would be $6,000. This is out of the question, since I paid $4,500 for the boat. And, now, the grandfather who is not as nice as his grandson, is trying to get out of it by saying that they did not hire the mechanic, they just let him work on their property. And I learnt he was on crack...I did not hire this guy, I gave a check at the counter to have my boat winterized. Now, another mech is going to estimate the repair costs, and if the marina does not want to fit some of the bill, I`ll have take other measures. This really sucks.
Aurel |
Free minder
Btw, $850 is the fee to leave the boat on trailer at the marina. The winterization was $175. And it looks like the "mechanic" bought $175 worth of crack.
Aurel |
Dog-faced pony soldier
Cripes. Just store the boat inside somewhere above freezing during the winter months and start it/run it once a month with one of those dual suction-cup things over the water intakes connected to a hose.
That's what we used to do back east. AFAIK the original Mercury outboard still runs great after all these years. Given how much marinas charge for "winterizing" and storage, it's actually cost-effective to stick it in a garage or heated storage place for a few months. One nice thing about Socal I guess - there is no need to winterize. Ever.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
What does the invoice/receipt say for the work performed? Who was the check made out to? Surely he can't argue against a copy of the receipt / work order from his marina along with canceled check made out to his company?
Free minder
Aurel Last edited by Aurel; 05-31-2008 at 01:11 PM.. |
Parrothead member
Without the work order and paying cash you are SOL.
That sucks. This is the reason nobody touches my boats but me.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." Last edited by VINMAN; 05-31-2008 at 02:19 PM.. |
