charleskieffner's Avatar
poll: cordless 1/2 impacts. whose best???
about to pull trigger on one. 1/2 cordless impact for porsche lug nuts(96ft-lbs)
my choices are all because of local factory service centers.
BOSCH
DEWALT
MAKITA
SNAP-ON
i can go to CPO BOSCH.com and pick up a 1/2 18v w/(2) batteries/charger/case for $289.00 or buy new for alot more. steering towards the bosch.
anyfeedback???? good bad ugly???? will it take (20) lug nuts OFF and install (20) lug nuts allowing all (4) tires to be changed out on (1) full battery pack?????????
Old 07-22-2008, 11:49 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
I've heard very good things about "the mother of all impact wrenches" made by snap on. Not cheap, but very good. A friend has one and loves it, changes the lugs on his 'vette over multiple weekends on one charge.
http://www.motherofallcordlessimpactwrenches.com/
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 07-22-2008, 11:55 AM
Go with Bosch. Your car will like you for it.
DeWalt = NASCAR
Snap-on is made by someone else.
Old 07-22-2008, 11:57 AM
Ferdinand Magazine
johndglynn's Avatar
I have used the Snap On, De Walt and now Makita. I preferred the Snap On but my buddy who owns the tools prefers the Makita. He reckons the De Walt was moderately useful for stirring tea and that was it.
Sheriff at www.impactbumpers.com
Brand support at classicretrofit.com/tuthillporsche.com
1976 Porsche 911 Carrera 3.0: 'The Orange' - 1981 924 Turbo - 1983 944 Lux - Too many BMW motorcycles
Old 07-22-2008, 11:58 AM
Banned
Get the Long Acre from Safe Racer (or Wayne if he has it). BY FAR the best IMO. $259.
my electrician ECHOED the same sentiments on the dewalt. stirring tea........LMFAO!
longacre ..........i actually have their catalog will check specs.
snap on..........$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $$$$$$$
Old 07-22-2008, 12:03 PM
I have a Dewalt which is pretty nice but it didn't compare to the Milwaukee that I borrowed at the track when mine failed to break my lug nuts. Definitely worth a look.
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 07-22-2008, 12:06 PM
$500 bucks for snap on. holy ned! yep usually tools like this are private labeled. but 600 ft lbs!!!! wow! i could do a pitstop on my K-3500 duallie if i had enough batteries! their 140 ftlbs on those lug nuts!
bosch 350 ftlbs torque.
Old 07-22-2008, 12:08 PM
Danny_Ocean's Avatar
Which DeWalt do you have? My DW059 is rated for 300 ft./lbs. If that ain't enough, the 36v DC800KL will go to 325 ft./lbs. Never had mine fail to remove a lug.
Old 07-22-2008, 12:12 PM
I like my Dewalt, yes Snap-On is nicer, but for my use, isn't worth double the cost.
Old 07-22-2008, 12:13 PM
Paid $99 for mine on E-Bay. Didn't come with battery or charger, but I already had those from my other 18v tools.
Old 07-22-2008, 12:14 PM
Super Moderator
cstreit's Avatar
I would encourage you to patronize our host, PelicanParts first. They carry several models (Makita, etc).
I have both, including the old Harbor Freight model which I take the track. It was $100 and has been great but unfortunately is NLA. Their new ones can't cut the mustard. All of the ones mentioned above work well from what I've seen. The Longacre version breaks lugs no problem and I even used mine on the big 915 transmission shoulder nut. Caveat Emptor, I sell them If you are interested in the the Longacre version I carry them for about $40 less than saferacer.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 07-22-2008, 12:15 PM
pwd72s's Avatar
Don't get me wrong...power tools are cool. But unless you're in a real hurry to change lug nuts, greater torque accuracy can be obtained doing them by hand...I used a 1/2" drive Snap-on Torque wrench...
A small amount of never seeze on the curved face of the lug nuts to prevent galling...tighten in an alternating pattern, 96 ft. pounds.
My favorite 19mm socket was the aluminum one sold by Stoddards...(sorry wayne)
The nylon insert soft sockets wear too quickly.
To remove, I used the same socket with a 1/2" drive breaker bar...
Old 07-22-2008, 12:18 PM
Originally Posted by cstreit View Post
The Longacre version is very good, breaks lugs no problem and I even used mine on the big 915 transmission shoulder nut. Caveat Emptor, I sell them. ( $40 less than the saferacer )
how much for the longacre??? and does it come w/(2) batteries and a charger??
You never install anything with a power torque wrench. Removal only. (Shhh...don't mention this to the tire guys @ WalMart)...
Old 07-22-2008, 12:22 PM
Super Moderator
cstreit's Avatar
Charles contact me offline if interested. That's for the 1 battery model with charger and case. There's really no need to pay for the second battery unless you plan on using it for more than a weekend without charging. My two batt. model is still abt $15 less.
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 07-22-2008, 12:23 PM
$250 ~ $350 depending on the # of batteries/chargers.
Old 07-22-2008, 12:24 PM
vash's Avatar
i have a milwalkee (i totally mis-spelled that, sorry). i can do three 911's at a track day on one battery easy. on and off. it is on the heavy side tho. it works circles around my buddies, dewalt.
poof! gone
Old 07-22-2008, 12:27 PM
Charles contact me offline if interested. That's for the 1 battery model with charger and case. There's really no need to pay for the second battery unless you plan on using it for more than a weekend. My two batt. model is still less though.
i will cstreit . just looked up longacre 24 volts vs. 18volts for bosch. i like that.
my drill on lug nuts from when i was 16 yrs old at johnson bozzani porsche audi.......
small amount anti-seize on each . tighten down-manjuelly. then use my trusty recently calibrated PROTO TORQUE wrencho to 96ft lbs.
actually im trying to kill ALOT OF HUMMINGBIRDS with one stone. my compressor at home is CRAP CRAFTSMAN SEARS EL JUNKO DORKO KAH KAH joke of a roll around compressor that barely runs my 3/8 air ratchet properly! sooooo to make it short i figured i could go to track, and have my cake at home for various vehicles all 1/2 ton chevies and the porsche at 96ft lbs. last i checked my 1 ton duallie was also 140 ft lbs torque on the nuts just like to 1/2 ton chevies. also i could use on quad tires since it seems i always get a flat elk hunting with all the damn weight we carry!
patrick moto here uses the snap on with a really cool soft socket that doesnt break the plastic innards out like the vertex socket i bought.
thanks for the feedback,
Old 07-22-2008, 12:54 PM
Super Moderator
cstreit's Avatar
Well I think you're on the right path... I bought and returned like 3 models before I settled on one that worked. Most will advertise 200 ft-lbs or torque but then they can't even break a lug-nut off. It's a crying damn shame that the HF model was discontinued. I've been carrying/using one in my race trailer for 5 years without fail.... The new ones they offer just can't cut it.
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 07-22-2008, 01:54 PM
