Home advice.
i've been getting outlets that are going out, and today it finally got to me..
been putting it off but now it's worrying me because i'm done to like every other outlet. i also rent soooo it's a PITA to get them to fix it.. i'm kinda werry about testing them because i hate to get shocked, but am unable to get any Volts form em..... sorry for the weird post but it posted it when i hit enter.....
dolor et pavor Copyright Last edited by Arizona_928; 07-31-2008 at 09:53 PM.. |
actually if the outlets are going out the installer ( probably the homeowner ) probably used the push connectors on the back of the outlet vice the screws. These push lock connectors come loose after a while. you need to find the breaker of the outlet and remove the outlet from the wall and use the screw terminals.
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
does your rental insurance cover fires?
Rick 88 Cab |
Bandwidth AbUser
Jim R. |
Did you get the memo?
+1 Not something to screw around with. Find the breaker and kill it. If you don't know which breaker, shut off the entire house. Pull the outlet, and see WHY it's losing power. Worst case, it's some sort or aluminum of older sub-par wiring that's corroded and breaking. In which case, the entire house should be rewired. Is the house newer, or old?
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
You do not have permissi
Don't do anything-except contact the landlord by email (for proof).
-If he doesn't fix them quickly (this is a fire-saftey issue), then put your next check into escrow and let him know why. -If the LL still doesn't respond, use the $$ to move, or hire a licenced/bonded electrician against your rent and/or contact the city housing department. Legally, it's not your house to modify. As per the lease agreement, you only "temporarely own" the property with conditions to maintain it in at the same standards. |
I don't think that I would go the "email route" because the person that was supposed to receive it can just say it never came through. I would use certified, registered mail, signature required, then you will have a hard copy, that they indeed did receive your complaint. Emails are too easy to say they never got there.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
Slumlord
Properly installed 'push-lock' connections are 100% safe. Provided the strip gage is used and the wire is seated to the right depth they are fine. UL doesn't approve unsafe concepts.
I would buy the $5.00 circuit tester shown here, test your outlets for polarity, power and ground, then notify your landlord of deficiencies in writing. Perhaps with your next rent cheque. He cashes the cheque, you know he got the letter.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
The push locks have a smaller contact area, effectively making them the smallest link on the chain. That may be ok for regular use (if the connections are correct), but why risk it?
Want to see a UL approved electrical device that failed on me big-time? (I carry a melted one in my work truck to show other electricians who use them) ![]() Although rated for 240v, I will only use these on low-voltage circuits now. |
Slumlord
I suppose I should have stated that quality name brand outlets were assumed. I wouldn't use low cost outlets, some risk is assumed, and very little money is saved.
As an electrical engineer I have zero concern with a properly installed push-lock on a quality outlet. But, I can see that if you are prone to worrying about this sort of thing, that a screwed on wire is superior. That's a given. On a protected 15 Amp cct the push-lock is fine. As far as arcing goes, eventually arc detection will be required on all circuit breakers. But your concern, for an improper installation, is valid. Arc detection is now mandatory here on bedroom circuits. A very good idea.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater Last edited by Porsche_monkey; 08-01-2008 at 09:15 AM.. |
I dated an electrical engineer...she didn't know squat about home wiring! I fixed a lot of stuff in her house that she attempted herself...
Slumlord
But the side benefits? Were they okay?
the house isn't that old either, it was an add-on to another house but that's another story its self
dolor et pavor Copyright Last edited by Arizona_928; 08-01-2008 at 01:23 PM.. |
rentals insurance what's that?
dolor et pavor Copyright |
Platinum Member
I have seen many screws loosen over the years also. Open any panel 5 years later, and the screws can be tightened on the breakers. I trust the push-ins. |
