Danny_Ocean's Avatar
How to activate a relay via the Internet?
I need (want?) to be able to activate a 12vdc relay remotely via the internet. I know how to wire the relay at the source, but how do I connect/control the contact via Internet?
Old 08-29-2008, 07:34 PM
Detached Member
Hugh R's Avatar
Vonage or something like that to ring a bell. Sort of like what the terrorists do using a cell phone to set off a bomb?
Hugh
Old 08-29-2008, 07:37 PM
Slackerous Maximus
HardDrive's Avatar
Who is the primary target?
2022 Royal Enfield Interceptor.
2014 Triumph Bonneville T100.
2014 Cayman S, PDK.
Mercedes E350 family truckster.
Old 08-29-2008, 07:40 PM
Nah. I need to buzz-in the UPS guy at my shop when I'm not around.
Also thinking about hooking up an air horn mounted outside the building. I'd like to be able to blow the horn when viewing my webcams and see someone poking around. That should get their attention...
Old 08-29-2008, 07:42 PM
Slackerous Maximus
HardDrive's Avatar
http://www.oopic.com/oopicr.htm
I have built a couple robots based on one of these little buggers.
2014 Cayman S, PDK.
Old 08-29-2008, 07:44 PM
Not sure I have the ability to make something work out of that! I know I need a controller of some sort. That would be plugged in to my server which is on 24/7 at the shop. N/O or N/C contacts would be wired to the door buzzer or horn.
Old 08-29-2008, 07:48 PM
Slackerous Maximus
HardDrive's Avatar
What kind of server? Windows? Linux?
2014 Cayman S, PDK.
Old 08-29-2008, 08:04 PM
Windows. It's not "technically" a server. Just a PC I keep running so I can log-in remotely to do my bookkeeping and check on the webcams. I log-in via a remote access program (sorta like PC Anywhere).
Old 08-29-2008, 08:06 PM
Slackerous Maximus
HardDrive's Avatar
If you want something off the shelf, you need to look at 'home automation' products.
http://www.smarthomeusa.com/Shop/PC-Home/
EDIT: Check this out: http://www.smarthomeusa.com/Shop/PC-Home/X10-PC-Interfaces/
2014 Cayman S, PDK.
slodave's Avatar
http://www.controlanything.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=NCD&Category_Code=CAT_RELAY2
Old 08-29-2008, 08:08 PM
Ah-ha...didn't even think about that. That's what I get for trying to think "outside the box"!
Thanks.
There you go...
Old 08-29-2008, 08:12 PM
Ayo Irpin, Ukraine!
70SATMan's Avatar
You need a PLC (programmable logic controller) set up. Configured for a static IP, connected to a router or to an Ethernet hub/switch off an existing router. Basically you need to set up a private network that has full time Internet connectivity. You also need a power source and logic output modules. The source feeds the input side to the output module. The PLC commands the output module to source the voltage to your relay.
There might be a PC based card that will do the same thing. In that case your CPU would always have to be on with VPN capability from your remote PC.
Harmlessly passing gas in the grassland away;
Only dimly aware of a certain smell in the air
Old 08-29-2008, 08:15 PM
Ayo Irpin, Ukraine!
70SATMan's Avatar
The entire world beat me to it.
Old 08-29-2008, 08:16 PM
Yes, PC is always running. I remote-in via PC Anywhere.
Old 08-29-2008, 08:17 PM
Fritz Peyerl's Avatar
remote
x10 unit's can control anything you want. I think Radio shack carries them. Very simple to install and use. My son controls most of his house that way.
Old 08-30-2008, 07:14 AM
