make sure the BIOS is set to boot from the cd drive before the hard drive. Many oems don't set the bios like this by default.
1983 944 This was probably posted from my phone, so please excuse any typos. |
Ok set the BIOS and now I think there is something wrong with the CD. If i try to make it install it just pops up a message saying /casper/vmlinuz then it doesnt do anything. Did i make the cd wrong. I did just check the Hashes and they dont match. Is that my problem how can i fix that?
There is an option, I think, when ubuntu first loads up, to vcheck the CD for errors. If it finds errors, you need to either re-burn it, try a slower burn speed, or your download is corrupted. Since your internet speed isn't the greatest, you can have them send you a free CD-ROM through the mail, but I think it takes a few weeks for it to show up.
Burn a new disk, making sure to have the burn tool verify the burn before completing.
ßrandon |
sudo apt-get purge 930
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
I think when it boots up, you can go straight to the install or run the live cd version and install from there. 8.04 had some cool updates for the installer, like verify the cd. Its more gui based too, than 6 and 7 where.
This is the MD5SUM for the iso you downloaded.
c69e34e92d5402d1b87e6babc739f774 *ubuntu-8.04.1-desktop-i386.iso If you boot from the CD and use the terminal to run: # md5sum ubuntu-8.04.1-desktop-i386.iso c69e34e92d5402d1b87e6babc739f774 ubuntu-8.04.1-desktop-i386.iso # The results should match with what I've posted.
ßrandon |
ok when i do an md5sum check it gives this number
329759D76672C27A7C815AE6B5FF5EFC Does that mean the install onto my HD is wrong? |
double post
No, it means the download got corrupted. You need to re-download, and re-burn.
I turn away with fear and horror from this lamentable sore of continuous functions without derivatives. --Charles Hermite Fakelife.com Nothing to do with archery anymore. Porsche/BMW/Ferrari/Honda videos Last edited by SlowToady; 10-08-2008 at 10:40 PM.. |
Crap. ok thanks i will try that.
By the way, it's a GOOD idea to make sure all your hardware is supported before jumping into things like this. It can save lots of headaches. Ask me how I know...
I turn away with fear and horror from this lamentable sore of continuous functions without derivatives. --Charles Hermite Fakelife.com Nothing to do with archery anymore. Porsche/BMW/Ferrari/Honda videos |
Gon fix it with me hammer
usb wifi sucks
get ethernet wifi bridge if you really need external wifi it's basically a box with wifi crap in it that plugs in your wired network card and no driver required (other then for your wired network card that is)
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Ok the download went good this time. Now time to burn the cd.
the usb will be ok in this case because he just wants the comp for basic web browsing. |
my beef with usb wifi , is that they cut out, don't have good antennas, low power and in my experience are a hit and miss ... half the time you boot up, the thing works, cut's out... pull it out, back in ... won't connect... reboot again...repeat
had it with different brands, on different pc's
Hmm. Guess time will tell. Signal shouldnt be an issue. Most of the use will be from his recliner about 15ft from the router
i hope it works for yours... my router was 9 feet away with clear line of sight
What brand of stuff was this?
Ok how long should that install take? I just ran it and it ran the little bar across the screen and then brought up the bird ubuntu background and then set there with just that on the screen and the cd driving running for a while and then the screen went black and it kept running the drive for about 30mins so i finally shut it off and turned back on and rebooted via hardrive and it is still running windows. i did the check disk thing on the disk itself and it said it was good
ßrandon |
