Jandrews's Avatar
Laptop Unable To Connect To Home WiFi
I have one laptop at home that is always connected to my DLink Wireless Router. I brought my work laptop home and it will not connect. It sees the wireless signal, but when I try to connect I get the message, "Unable to Connect to DLink". I had WAP security on the router but it didn't even prompt for a password. Then, I disabled the security temporarily and it still just gives the same message, with no other explanation or alternatives.
This same laptop has connected at home before, but for some reason, now it won't. Any thoughts?
Thanks,
JA
John
- '70/73 RS Spec Coupe (Sold)
- '04 GT3
Old 10-26-2008, 02:51 PM
slodave's Avatar
Disable any firewall SW on the laptop and see if it helps.
Old 10-26-2008, 02:53 PM
Jandrews's Avatar
Hey dave...how can I locate the firewall SW?
Thanks,
JA
John
- '04 GT3
Old 10-26-2008, 03:00 PM
slodave's Avatar
If if is XP, try to go control panel -> Windows Firewall and disable. You could have third party software installed as well. McAffe, Symantec...
Old 10-26-2008, 03:05 PM
Formerly bb80sc
Vipergrün's Avatar
Is the wireless interface on the laptop configured for static or dynamic (DHCP) IP addresses?
On your wireless router, are you using MAC address authentication? You would have had to configure this. Basically lets only specified computers to connect to the router.
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 10-26-2008, 03:06 PM
Jandrews's Avatar
Looks like Windows FW is not running, but it does have Symantec running. I disabled Symantec and tried to connect - still no joy - same message.
JA
John
- '04 GT3
Old 10-26-2008, 03:11 PM
slodave's Avatar
Try Brad's first suggestion.
Start -> Run -> "cmd" (without the quotes)
Type in "ipconfig" (without quotes) and hit enter....
"ipconfig /all" will give you even more info.
Old 10-26-2008, 03:13 PM
Jandrews's Avatar
DHCP Server is "enabled" on the router.
John
- '04 GT3
Old 10-26-2008, 03:22 PM
slodave's Avatar
But is the client - your laptop set for DHCP as well?
Old 10-26-2008, 03:28 PM
Jandrews's Avatar
How do I check for DHCP on the client?
JA
John
- '04 GT3
Old 10-26-2008, 03:31 PM
slodave's Avatar
Follow the steps in post #7 ^^^
Use the "ipconfig /all".
Old 10-26-2008, 03:33 PM
Jandrews's Avatar
Dang...Sys Admin has prevented me from even running the CMD command on the client laptop from work. Any way to check this from Windows?
JA
John
- '04 GT3
Old 10-26-2008, 03:40 PM
slodave's Avatar
You can try:
Start -> Settings -> Network Connections -> right click on the Wireless Network Connection -> choose properties.
Highlight "Internet Protocol (TCP/IP) and select properties... It may let you see if it is set for DHCP or static. I doubt you will be able to change any settings though.
Old 10-26-2008, 03:46 PM
Jandrews's Avatar
Thanks Dave. DHCP is "enabled" on the client. Might also we worth pointing out that this laptop doesn't seem to have any trouble connecting to other WiFi networks...just mine at home.
John
- '04 GT3
Old 10-26-2008, 03:52 PM
slodave's Avatar
If your Co. has locked down your laptop, it'll be a little hard to resolve the issue.
Old 10-26-2008, 03:58 PM
Jandrews's Avatar
Yeah...I can see how that might make it hard to diagnose. That said, should DHCP be enabled? Again, this laptop connects fine to other WiFi signals. And my other laptop (the one I am typing on), connects fine to my home WiFi. Strange. Any other thoughts on what to look for?
Thanks,
JA
John
- '04 GT3
Old 10-26-2008, 04:01 PM
slodave's Avatar
Yes, it makes sense that DHCP is enabled.
Some of the steps I may try, would be to set an I.P. and Netmask address on the work laptop and see if this makes a change. Problem is that you probably can't make that change on the laptop due to admin rights.
Old 10-26-2008, 04:12 PM
This is probably a stupid question...but did your wireless key on the top row get changed? Or on some computers there is a switch on the side to enable wireless???
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 10-26-2008, 04:13 PM
Jandrews's Avatar
steve...not a stupid question. But yes, wireless switch is turned on.
Thanks,
JA
John
- '04 GT3
Old 10-26-2008, 04:15 PM
Jandrews's Avatar
dave...how would I set an IP and SubMask on the laptop?
JA
John
- '04 GT3
Old 10-26-2008, 04:16 PM
