IROC's Avatar
Any suggestions for a machine shop that can handle large assemblies?
Anyone know of a any good machine shops that can handle large assemblies? Primary materials involved the fabrication would be 316 stainless and beryllium. EDM and electron beam welding would be required along with relativley close tolerance machining (+/- .005 on alot of stuff). Need to be able to machine and integrate assemblies weighing in the neighborhood of 20 tons or so.
Any ideas?
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 11-21-2008, 05:58 AM
Steve F's Avatar
Can't say for sure, but one would think perhaps near a ship yard or sub building area would be able to handle something like that. I was E-beam welder for Hughes Aircraft for 8 years, a very cool machine
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate
1967 912-1985 Toyota FJ60 Landcrusier
1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4
1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag
1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS
Old 11-21-2008, 06:31 AM
Cars & Coffee Killer
legion's Avatar
Lendaddy runs a machine shop and is looking for work.
5 liters of VVT fury now
-Chris
Old 11-21-2008, 07:16 AM
IROC's Avatar
I hadn't thought of shipyard-type places. Good idea. Is anyone familiar with Remmele Engineering (in MN or WI?). They built some stuff for me years ago and they seem like a shop that could handle what we need.
We've got several large assemblies that need to be manufactured (some in the millions of $$ per assembly) and no one seems to want to bid them.
Mike
1976 Euro 911
Old 11-21-2008, 09:02 AM
IROC's Avatar
For instance - we need another one of these made (the thing hanging from the crane):
Mike
1976 Euro 911
Old 11-21-2008, 09:08 AM
crustychief's Avatar
The warp core for the Enterprise?
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 11-21-2008, 09:15 AM
Mike, Al Myers at Flambeau metals in WI can probably help you. I kknow he used to do huge rollers for paper mills. If not he can steer you in the right direction.
Warren
Old 11-21-2008, 10:35 AM
IROC's Avatar
Warren
I'll check into this. Thanks.
Mike
1976 Euro 911
Old 11-21-2008, 10:45 AM
David's Avatar
I could help you with big rotating equipment, but not that monstrosity
Old 11-21-2008, 12:27 PM
"The warp core for the Enterprise?"
Looks like a particle beam target/moderator to me.
Old 11-21-2008, 05:22 PM
Stressed Member
GDSOB's Avatar
Wish I could help you, but too big for our shop.
General Tool or Magna Machine in Cincinnati have equipment that can handle that size job.
Garth
70 911E
08 Buell XB12XT
Old 11-21-2008, 05:26 PM
Well, I've got a milling machine in my garage............
Seriously,
Check out this site: http://www.practicalmachinist.com/vb/index.php and perhaps post an inquiry here: http://www.practicalmachinist.com/vb/forumdisplay.php?f=34
Practical Machinist seems to be the Pelican of the manufacturing world. Mostly knowledgeable professionals and shop owners, and the board has a serious yet helpful feel. (Plus, I can surf the site at work and not feel like I'm goofing off )
Best of luck,
Jim
Old 11-21-2008, 07:11 PM
Dept store Quartermaster
lendaddy's Avatar
Yea, that's well outside our abilities. Cool stuff and I wish we could but he needs a shop with big big dollar equipment and expertise.
electron beam welding is very very cool.
Cornpoppin' Pony Soldier
Old 11-21-2008, 07:30 PM
7.0:1 > 11.3:1 > 7.0:1
So, what is that thing?
Old 11-21-2008, 10:45 PM
Monkey with a mouse
kstar's Avatar
Looks like a cylindrical core of prefabulated amulite, surmounted by a malleable logarithmic casing in such a way that the two spurving bearings are in a direct line with the pentametric fan. ... The main winding of the normal lotus-o-delta type placed in panendermic semi-boloid slots in the stator, every seventh conductor being connected by a nonreversible trem'e pipe to the differential girdlespring on the 'up' end of the grammeters.
In other words, the guts of a turboencabulator.
Kurt
http://starnes.com/
Old 11-21-2008, 10:56 PM
IROC's Avatar
You're actually pretty close. It's called an Inner Reflector Plug. It has liquid hydrogen upper and lower neutron moderators that are cooled with gaseous helium, beryllium reflectors, cadmium coated neutron reflectors and lots of stainless shielding. All water cooled. Our liquid mercury target module fits into one of the slots in the bottom and it's position needs to be controlled to within +/- .010". And the target weighs 100 tons. Not an easy task positioning 100 tons to that accuracy...
Mike
1976 Euro 911
Old 11-22-2008, 04:36 AM
David's Avatar
We just finished work on a 90 ton gas turbine. The tolerances on it are with 0.002" and within 0.0005" on the journals. The size of your piece isn't the problem, it's all that stuff hanging out of it.
Old 11-22-2008, 07:44 AM
Registered abUser
TerryH's Avatar
Have you checked Craigslist for a slightly used one?
'81 911SC Coupe SOLD
Old 11-22-2008, 07:54 AM
IROC's Avatar
Yeah, we had one of these made a few years ago and it didn't go too well - lots of problems. Now we need another one and everyone is no-bidding. It is extremely complex and the size conspires against us.
Mike
1976 Euro 911
Old 11-22-2008, 07:56 AM
IROC's Avatar
Yep, there's one on ebay right now with a decent "buy it now" price but the guy wants too much for shipping.
Edit - funny you mention "used". I will be in charge of replacing this when the time comes and the radiation levels this thing will possess are going to be mind-boggling. Probably in the neighborhood of 10^8 rem. Try handling something that radioactive that is that heavy. Not going to be fun.
Mike
1976 Euro 911
Old 11-22-2008, 07:57 AM
