disband
diff lube weight questions??
looking for some info on gear lubes as the two diff boxes and auto tranny fluids are up next on my new to me 02 wrx "get to know er maintanence" schedule.
the fluids recommended for the front & rear diffs are a 75-90 and an 80-90 wts and i was wondering if i could just go 80-90 in both without concern? i know what the viscosity numbers mean and living in cal i dont get wide swings in temp but is the low end 75 V. 80 a big deal? i am thinking of sweepco from the host if a 80-90 will suffice on both. thoughts?
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
disband
bump
canna change law physics
With the mention of SWEPCO, this should be moved to the religion forum.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
LOL! SWEPCO! Sweet Old Bruce sez so... ![]()
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
That's fine. Only thing to check is if you need to add some anti-slip additive, or it may built into the fluid you use.
disband
subaru is spec'ing a GL-5 grade and the swepco says it meets that so i suspect i will proceed.
Targa, Panamera Turbo
The first number refers to the cold temp viscosity - the second number is what is important, refers to the operating temp viscosity. The problem with SAE designations is trhat there is a range which is pretty wide.
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
oh ya, to answer you question - yes, you can use 80W90 for both.
