Somewhere in the Midwest
MotoSook's Avatar
Yes, Dave. I'm in the old drive trying to open the "User" folder. "Administrator" and "All User" folders are accessible, but not "User" where all my data resides.
Old 12-06-2008, 09:00 PM
slodave's Avatar
1. Launch Windows Explorer or My Computer.
2. Click on the Tools at the menu bar, then click on Folder Options.
3. Click on View tab.
4. In the Advanced Settings section at the bottom of the list, uncheck and unselect (clear the tick) on the “Use simple file sharing (Recommended)” check box.
5. Click OK.
Do the above, then see if the security tab shows up, if so, try my other instructions.
Old 12-06-2008, 09:06 PM
MotoSook's Avatar
I was able to do the above and was able to open the User folder, but sub-folders are locked and I can't use the same method to unlock them.
Old 12-06-2008, 09:18 PM
slodave's Avatar
That's what I thought. Get back to the security tab as before....
At the bottom right, you will see a tab called Advanced, click it...
Add Everyone again... Check Full Control, wait then see if you get access...
Old 12-06-2008, 09:22 PM
MotoSook's Avatar
It's going to take me all night to do that to every subfolder and file....no other way huh?
Old 12-06-2008, 09:29 PM
slodave's Avatar
No, only on the "User" folder. It should then apply to all sub folders/files.
Old 12-06-2008, 09:32 PM
MotoSook's Avatar
I must be doing something wrong. It did not apply to sub folders and files.
Old 12-06-2008, 09:33 PM
slodave's Avatar
Is the user "System" there? Also after you added Everyone, what did it say above Full Control? Make sure it says Apply onto: This Folder, subfolders, files.
Old 12-06-2008, 09:37 PM
MotoSook's Avatar
In the Advance window of the security setting, it lists full permission for everyone (System is there too). "Inherited From" = not inherited. "Apply to" = "This folder, subfolder and files"
I figured that was right...but no entry to sub folders unless I manually unlock them like earlier.
Old 12-06-2008, 09:43 PM
slodave's Avatar
This link should do it:
http://www.z-a-recovery.com/art-recover-userprofile.htm
Start from step 3.
Old 12-06-2008, 09:59 PM
MotoSook's Avatar
I'll give a shot..if not, I'm hitting the sack. It's midnight here....I'll get back on it tomorrow.
Thanks for all your help, Dave. I hope you feel better.
Old 12-06-2008, 10:04 PM
MotoSook's Avatar
YES! Yes!
It worked, Dave. It took a while to change ownership of all the files, but it worked!
Thank you so much for your time and patience. If there's anything I can do for you....don't be afraid to ask.
Old 12-06-2008, 10:27 PM
slodave's Avatar
You are very welcome. I always forget about this issue. It doesn't always come up.
Old 12-06-2008, 10:28 PM
