I would prefer to see pictures before commenting, but anything is possible.
Adding a dormers or raising the roof is the best suggestion so far. Pictures please. |
Thanks for all the replies -- I'll post pictures in a bit. The best pictures, of course, will come after closing.
A little more information: - The original footprint of the house is only 24x28, so it's not monumentally large. Milt -- good thinking only doing part of it, but it's small enough that it wouldn't make sense to only do half, or something. I'll bounce it off my wife, but I think if we're going to go, we'll go all the way. - The roofing is relatively new, and looks great from the outside. From the inside, the timbers look to be in decent shape, but the joints may be showing their age. Perhaps replacing the roof is a good plan? - Asbestos siding makes any work on the exterior of the house prohibitively expensive. While some work will eventually be necessary, I'd like to avoid crossing that bridge any sooner than I have to. There's also vermiculite insulation, though, so that's still problematic. - The bearing wall situation is really simple: the house has a single central beam down the long axis, 28 feet long. It splits the house into 2 twelve foot halves. (My suspicion is that the builder got a deal on 12' lumber.) The bearing wall for the main floor clearly sits on this central axis, and divides the main floor cleanly in half. The central beam has seen better days: someone sistered in a newer beam alongside it, and sistered in supports for the basement posts. This is obviously work that will need to be redone correctly. GWN7 -- you sound like you've got real experience with this. And looking at the construction of the house, I suspect you're right. We'd have to figure out how to hold the roof together, if we pulled the floor out. I've seen cables used to do that, but I suppose that's not the right way to do it. What if we used cables for a short-term solution, then went back and rebuilt the roof 10 years from now when it needs it? We could use reasonably modern roof trusses, and maybe get away with it? Fint -- I'll send procon an e-mail -- if there's someone who's comfortable working on a house of this age, it might make a lot of sense to pay the costs for his experience. Thanks for the reference. I'll end up hiring a pro to at least come at look at the site to discuss options. My wife is a nanny, and knows a whole collection of interesting professionals, one of whom is an architect. We can probably get some basic ideas for the cost of a Friday night of babysitting. Dormers may be the simplest option, but they also provide the least reward. As you can see, there's already one, and it barely helps. We could add another on the other side, and enlarge the first. ... Much as I hate to admit it, it might be the only option in our price range. Thanks for all the insightful comments, everyone. Dan PS -- some pictures. I can provide more once I close on the house, and have a few more shots that I took during the home inspection. --Inside the crawl space / attic ![]() --Inside the crawl space / attic ![]() --From the front
'86 911 (RIP March '05) '17 Subaru CrossTrek '99 911 (Adopt an unloved 996 from your local shelter today!) |
Navin Johnson
Dan... I apologize for the little hi-jack up there ^^
I live in a house built in the mid 20's..in 1920's The first two pictures you posted could be in my house... Is that daylight I see in pic one? ![]() One thing to consider since you say you will stay in the house during construction... you need to go up!! dormer etc.... if you pull out and change the elevation of a floor... the house will be unlivable for a period
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
What is the headroom at the center of the attic, under the ridge of the roof?
Are there permanent stairs to the attic? If it is reached by pull-down ladder etc, is there room to put permanent stairs? I'm thinking, find the least expensive alternative that allows you to finish the attic as a master suite w/ bath. For that use, you don't need standing headroom everywhere, e.g. not over the bed. Dormers would be cheapest and you could certainly live in the house during the work. New roof structure, with higher ridge and either steeper and/or gambrel (barn roof) style would be significantly more expensive. Lowering the floor would be way more expensive, not really practical IMO. For each option, figure out how much you will have into the house, and how that squares with market values in the neighborhood. Don't want to over-improve and/or invest more than will get out. If you wanted to post a floorplan w/ dimensions, I'm sure you'd get some good ideas. Oh, the other place to look for more living space, is the basement. What is headroom to joists there, is it dry, is floor dirt or concrete or?
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
After looking at the photos, I think the best option is dormers. Expand the existing one and put one on the oposite side. That is if there was a dedicated stairway to the second floor already.
This would enable you to move the master bedroom to that space and add a second bathroom. It appears to be the most cost effective means of adding living space. If you take the roof off and add a second story you will need to have the foundation certified that it will handle the extra load. Not to mention you will have to get approval to do so. Is there existing two story homes in the neibourhood? If not they might not approve the request. As there is a existing dormer you will get approval easier to add another one. If you want to lower the ceiling height on the main floor (as per your first post) the roof will have to come off and you will have to gut the interior of the house. A new floor (for the second floor) will have to be attached to the outside walls which means rebuilding the ouside wall supports. Very expensive and very stressfull if you and your wife have to live in the basement like mole people for 6 months.
Bunch of old cars
TimT -- I suspect it is, in fact, daylight. Project #1 is closing the house to the elements. Blech.
JYL, the roof is 12' on each side, so the ridge height is about 10'. Inside the "finished" space, it's approx. 6' head height in the middle, and slopes down to about 4' on the sides. The stairs up are permanent, but were probably also not part of the original design. It looks like a bedroom closet was gutted to make room for the stairs. We're thinking that it would be nice if we could move the floors, but making the structure of the house continue to work with the stairs somewhere else could be an interesting challenge. The basement has 6' head height in most places, with a concrete floor. It's really more of a cellar than it is a basement. It will never be approved as living space because of that low height. GWN7 -- thanks for the information. There are existing two story homes in the neighborhood, but only one or two. One other idea might be to ask the neighbors what they've done -- there are a couple of other houses in the neighborhood that are the same model, so perhaps those owners could provide some wisdom. I definitely like the idea of less struggle getting permission -- rumor has it that the Gaithersburg permitting office is somewhat draconian. I think the collective wisdom of the board has spoken: dormers, not moving the floor. I'll make up a floor plan in a bit and post it to solicit floor plan improvement opinions. So to hijack my own thread ... One of the interesting things about this house is that it's a kind of forensic construction project. No construction work has been done in the last 30-40 years, so everything has that old patina on it. But some work is obviously not from 1927 -- like the stairs, or the kitchen addition. The kitchen is obviously NOT from 1927, but the stove says "Kitchenaid, made in America by General Motors Corporation" on the front, in neat little script. It's a treasure in its own right.
Don't what you (or local code) think about spiral stairs. I think they are cool and save lot of space.
Ooof, if literally just 6' headroom at the tallest point of the attic, that's not helpful. Quote:
Actually I plan to build out basement in our house, will need the large window wells too. Project on hold.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? Last edited by jyl; 01-19-2009 at 09:33 AM.. |
Bandwidth AbUser
TimT, any idea where Hoffa's resting?
Jim R. |
The basement idea is great, but I don't think this house is worth it. I mean, it's a nice 1927 bungalow with a lot of neat little features, but ... it's not worth that kind of effort to modernize it. We'll tear down the kitchen/breakfast-nook addition and rebuild it before we dig up the basement.
Dan
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
The problem with hand digging out a dugout type basement is the footing walls. They usually only extend down below grade 2'-4'. If you dig out the basement there is no support for those walls and the weight of the house will cause them to push inwards as there will no longer be anything holding them in place on one side. You can leave 4' of earth (braced) on the inside to support the outside walls, but that sort of defeats the purpose of creating living space down there. Then there is the 224 cubic yards of material your going to hand bomb out in pails (24X28X3/9) That's about 2700 5gal pails of dirt to lug. Cancel your gym membership, you won't need it while your digging. ![]() Easier and safer to lift the house off the basement. Move it back, demolish the existing basement. Dig and build a new basement and then move the house back on to it. If space is a restriction on moving the house, it can be lifted and a new basement can be built under the house.
Bunch of old cars
I don't know if it was mentioned, but I see a reason for the low 2nd story ceilings. That's a single story house with a converted attic.
My old house...Before:
![]() After (with vaulted ceiling):
