Free minder
Question for network gurus
I may spend the day trying to figure this out, so I thought I might as well ask the pros...
I have connected a wireless router (Linksys WRT54GC) to my office LAN network in order to access the network from my wireless computer. In order to acces internet, I have given the router my desktop PC IP adresses on the LAN side, and I have cloned the MAC adress of my desktop PC. I have given another IP to the desktop PC. It works fine to access internet from the laptop, but I can`t see the other PCs on the LAN. Now, I would like the laptop to see all the LAN computers behind the wireless router. How do I do that?
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
The Unsettler
Confused at what you did.
Was/is your network controlled by your desktop? Meaning WAN comes into it? Typical setup would be your WAN goes into the Linksys which can be left as the default DHCP server. You can also leave the Desktop, laptop and other computers as dynamic clients on the LAN side and everything will be visable.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Free minder
You've confused the heck out of me too with your "hacking"
![]() Last edited by KFC911; 01-27-2009 at 05:33 AM.. |
OK, if the Linksys won't be your router and you just want the wireless function of it, you need to NOT use the WAN port on it. Go from your existing switch/hub into one of the switch ports (LAN side) on the Linksys. Then it will just act as another switch on your wired network and as an AP for your wireless. You'll want to disable DHCP, etc. on the Linksys.
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
Free minder
Slackerous Maximus
CSMA/CA no likey cloned MAC addresses.....if I understand correctly.....
2022 Royal Enfield Interceptor. 2012 Harley Davidson Road King 2014 Triumph Bonneville T100. 2014 Cayman S, PDK. Mercedes E350 family truckster. |
Right, you shouldn't need (actually should avoid) cloning a MAC.
As stated, you should just be able to use the switch ports to connect to the network without doing anything else fancy. Connected this way, all of the PCs wired or wireless should be on the same network. Then as long as the PCs have networking setup correctly, they should be able to see each other and get to the internet. I assume you have another router acting as the internet gateway or are you sharing a connection from the wired PC?
Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa ![]() |
Free minder
And our network is already hacked by the russians anyways ![]()
Thread Tools | |
Rate This Thread | |
