MBruns for President
So I have this hatch on the boat... need advice...
That is two part - fiberglass outside with "clear" insert that allows light to enter.
The clear inside is some sort of plastic polycarbonate/lexan type. Needless to say over the years - it's crazed - and not so clear anymore - more of a pinky color... . Any advice on replacing that inside panel? Can I just used a smoked lexan? Any way to make a slight crown in it? ![]()
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Did you get the memo?
Could you replace it with plexiglass? It's easy to cut with a table saw (or knife if you have steady hands) and pretty robust.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
Navin Johnson
I had a boat with a similar hatch, the frame of the hatch was crowned..Smoked lexan or plexiglass will work. When you bolt the replacement in, it will curve to follow the profile of the hatch..
Just bed the new piece in a bed of silicone.
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
MAGA
+1 to what he said /\ Plexiglass/Acrylic is more scratch resistant than Lexan/Polycarbonate (and is cheaper too), however Acrylic will not be as break resistant. Whatever you use, just be sure to drill the holes oversize (and deburr) and do not over tighten the screws so that expansion contraction can occur to avoid breakage/cracks at the screw holes.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
If the frame isn't crowned I've seen guys use heat guns to mold lexan slightly. If needed, clamp lexan to frame (out of boat), frame upside down and carefully heat lexan until gravity helps shape.
'73 911 and other cool stuff |
The only way to make a compound "crown" would be heat. If the hatch frame is flat and you want a hump, you can go N/S or E/W. I would cut some teak in a slight curve to hold the edges of your curvature on 2 sides. Silicone will definitely seal against the weather.
To do a nice silicone job, mask on both sides of the intended bead. Then dip your finger in soapy water to smooth the bead out. Pull the tape while the silicone is wet and you'll have a very nice job. |
Thanks guys - that's kinda what I was thinking
Gon fix it with me hammer
real pirates didn't wet their finger for no beads
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Just finished this project over the weekend - went with some 3/8 smoked lexan.
Had to trim the edges a little because of the thickness - but dimensionally it's a much more stable piece. BEFORE ![]() AFTER
Nice job, huge improvement. Weird that the old went pink.
That's the kind of thing that makes me love this place. Someone is always coming up with a little bit of gold.
Vafri
Very nice.
