Poll: The quantity of oil dumped down sewers each year by car owners in the U. S. is ...
Poll Options
AutoBahned
RWebb's Avatar
a multiple choice oil pollution question
Old 02-24-2009, 11:26 AM
unindicted co-conspirator
looneybin's Avatar
funny you post this today.
I changed my oil on sunday & missed the catch bucket & spilled about 2 quarts of dirty oil on my driveway.
I was able to get most of it up, but there was still some residue i couldn't get, even after both simple green & cola
It made a nice sheen in the gutter
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 02-24-2009, 11:34 AM
looneybin's Avatar
BTW my neighbors made the "exxon valdez" comments as i was mopping up the spill
Old 02-24-2009, 11:35 AM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
My theory is that by pumping oil out of the ground, we remove the valuable lubricant required by the tectonic plates that allows them to slide past each other smoothly, and effortlessly. Pouring used oil back on the ground allows it to slowly penetrate, back to where it belongs, doing the job that god intended it to. (IE=Intellgent Engineering).
I'm doing my part to avert natural disasters and save mankind.
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 02-24-2009, 11:56 AM
Used to be Singpilot...
Location: Sioux Falls, SD is what the reg says on the bus.
Another 'funny you should ask' polls. For the first time ever, the NAPA place I took my used oil to has set a 5-gallon limit to recycle. Per month. And they won't take the containers (usually windshield wash gallon bottles) back.
My Stepvan with the 3.9 turbodiesel has a 7 gallon change with the filter. Add in two 10K gensets, power washer, log splitter, '80SC with the big cooler, 944, Prius, Toyota truck, and 454 motorhome, all done in the same month.
I was all over town spreading it between places that still take oil back. I thought the rule was you sell a certain quantity of oil, you have to take it back to be 'recycled/disposed of'.....
Old 02-24-2009, 12:15 PM
AutoBahned
RWebb's Avatar
huh - well, those are local rules
around here, they do curbside pickup of used oil at every house
try calling your municipal or county land fill/ garbage people
Old 02-24-2009, 01:52 PM
AutoBahned
RWebb's Avatar
Originally Posted by dhoward View Post
M... Pouring used oil back on the ground allows it to slowly penetrate, back to where it belongs, ...
I hope that was a joke.
Pouring used motor oil on the ground is illegal everywhere that I know of. And for good reasons.
Fresh motor oil is not too bad (do not use on salads tho). But used motor oil is full of toxic metals - which will never break down. It is also full of combustion by-products -- long chain and cyclic organic molecules, many of which are very toxic. They can persist for many years, perhaps decades.
Dumping it on the ground puts it into the groundwater and pollutes lakes, streams and rivers once it works it's way there. While it is in the ground water, it pollutes drinking water supplies in wells.
Spilling crude oil - even a heavy crude - is not as bad per pound as spilling used motor oil.
Old 02-24-2009, 01:57 PM
Friend of Warren
But the dirt will filter out all the bad stuff and just allow the good oil to seep back down to where it came from.
Kurt V
Old 02-24-2009, 02:03 PM
Just thinking out loud
mattdavis11's Avatar
The water table around here is way down there, so I'm not at all worried about it causing problems. Just dig a good sized hole and send it back home.
91 FJ80
84 Ram Charger (now gone)
Old 02-24-2009, 02:23 PM
Custom User Title
rammstein's Avatar
Oil helps trees to get fatty acids they need to convert harmful CO2 into healthy oxygen.
Old 02-24-2009, 03:59 PM
Zeke's Avatar
Randy, re oil in the sewer, bad idea. But, have you considered the amount of grease, fat and products that contain liquid petroleum that is flushed down our waste systems? I thought the sewer treatment plants did fairly well with this.
Wassup?
I'm sure the answer is twice as much. It's a pretty damn big place.
BTW where do I find the hole that leads to the right tectonic plates? (Of course he was joking)
Old 02-24-2009, 04:14 PM
dhoward's Avatar
See.
Kurt knows.
So does Mo_Gearhead I'm sure.
Only you can prevent earthquakes.
Dan
1969 911T (sold)
2008 FXDL
Old 02-24-2009, 05:46 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
I just chuck mine into the grease trap behind the local Burger King.
Black Cars Matter
Old 02-24-2009, 06:27 PM
pwd72s's Avatar
I save all my used motor oil, so I can help reduce the dust on logging roads near the McKenzie River here in Oregon.
Old 02-24-2009, 08:44 PM
pwd72s's Avatar
That'll work...environmentalist whackos can convert it into diesel fuel, right?
Old 02-24-2009, 08:47 PM
AutoBahned
RWebb's Avatar
Wassup?
That will go to a POTW - i.e. a sewage plant. I doubt they like it very much, as the bacteria there like to run on pure $h*t. The plant engineers are always trying to convince people not to use the garbage disposal to keep food out of their $h*t.
And... that grease is less harmful than motor oil for the reasons stated above. It used to be food right?
Of course, there are better things to do with that grease -- a lot of places here save it and sell it to the bio-diesel fuel-maker folks around here.
It's sad that Paulie has political problems with using it as a fuel source.
Old 02-24-2009, 09:26 PM
I thought it helped keep the drain pipes lubed up and free from clogs.
Black Cars Matter
Old 02-24-2009, 09:30 PM
