Not sure about the minwax stuff
I'll take a closer look at the can when I get home tonight. I'm assuming it's a hybrid/poly based, since I do remember it warned to use only in a well ventilated area. it also seems to dry in about a day.
I think I found something online that said that the minwax is one of the "wiping varnishes" but that the oil additive is tung oil. So you have some tung oil in your "Tung Oil".
Thanks Steve. I checked the can and the Minwax website, and neither lends any clues as to what I'm wiping on. There's a VOC "rating" on the can of 5lb per gallon. I tried calling Minwax, but they closed before I got home. Will try again tomorrow.
OK - so this has now become an obsession, but I've found the following on a woodworking BBS:
"If you want someting easy to apply, and strong, choose one of the oil/varnish blends, but don't expect to just wipe it off with mineral spirits. Watco, Deftoil, Minwax Tung Oil finish, etc, are examples." So it sounds like the Minwax has some tung oil in it, but is definitely not the pure stuff. |
Here's something I found
http://www.sawmillcreek.org/showpost.php?p=262442&postcount=11 Quote:
How about just some olive oil. We all eat gallons of those. It jsut have to serve its purpose to protect the wood from moisture. What little is left on the lid. Try Boos ( I think that's the name) cutting board sealent. that's stuff works wonders.
Olive oil does not dry. |
Knew a guy that built log homes. Said that tung oil is the absolute best finish. The real stuff - cut with turpentine as I remember.
He also said the US Army uses loads of it. Keeps cannon barrels and other things from rusting apparently. |
OK - just got off the phone w/ Minwax. Their Tung Oil Finish is:
Tung Oil (48%), Lemon Oil, Mineral Sprits & Varnish They wouldn't give me all of the ratios, but I didn't press it either, as I was mostly curious about the tung oil content. |
I was hoping it had a decent amount considering the price was in line with the pure stuff on the realmilkpaint site.
Warning!!!!
Genuine tung oil is made from a highly toxic seed nut that resembles a Brazil Nut. The trees have the seed pods that are almost round, about the size of a tennis ball. There used to be a decent market for the seeds, but with the products made from them is so toxic, there is no real market for them anymore. I used to have a tung nut tree orchard on an 80 acre section of land, and towards the end of market for the nuts, you had to go further and further to sell them, because so many companies that did make tung oil products, just about totally quit marketing them do to liability issues, because the products were so toxic. :eek:
The tung nut tree is fast growing and bears a lot of the ball like seed pods. There used to be a lot of those trees growing along the side of I-59 going through Mississippi. The "nut" looks almost like a Brazil Nut, and for many years, just about every year, there would be a handful of poisonings of tourist that thought that is what they were eating.:confused: This is a highly toxic neuro-poison, with no known antidote. I, personally would NEVER use any type of tung nut product, and I also destroyed all of the trees that used to be in that orchard. Cut down, bulldozed, and removed all traces of them that I could find. There is still some scattered around the 160 acres, but not an orchard with row after row of them. I would certainly recommend to anyone, to choose a different product, due to the toxicity of the tung nut and the products made from them. I know what I am speaking about, because of commercial harvest, and have first hand knowledge of poisonings that have been due to them being eaten mistakenly for Brazil Nuts. If you really are dead set on using it, just make sure that it is on something that will not come in contact with anything that could possibly get ingested. Tony. SmileWavy |
The Tung nut is toxic and can cause death, but the oil is not. http://jpet.aspetjournals.org/cgi/content/abstract/74/2/114 Quote:
http://www.accessdata.fda.gov/scripts/cdrh/cfdocs/cfcfr/CFRSearch.cfm?FR=175.300 The MSDS Quote:
