AutoBahned
RWebb's Avatar
ipod interface to car stereo
I bought a VW Vanagon recently and it has a nice Alpine head unit in it.
But it is very old - a cassette unit.
I have an ipod FM tuner type interface and that works. I will be using it in rural areas mostly - way rural - i.e. Oregon outback areas.
Would one of those interfaces that plugs into the cassette well (works via the tape player head) be better than the tuner type unit?
I'll jerk it out of there for a more modern unit eventually - maybe later this year or next. Need something now. Alpine says there is no way to interface an ipod directly into this ancient unit...
Old 04-02-2009, 04:10 PM
I have heard decent stuff about those. They are only like 15 bucks. Worth a try. The fm tuner can be a pain because of having to change stations.
Old 04-02-2009, 04:16 PM
N-Gruppe doesn't exist
teenerted1's Avatar
Location: *%@#ing GPS, where am I? Oh wait I see the Space Needle.
Send a message via AIM to teenerted1
tape deck adaptors work just fine. will get some noise of the spindles turning but the audio wont be effected. the head unit will still get warm since the motor is runing.
that is what i used in my 914 since the radio reception sucked with the antenna mounted under the engine mount bar????
Ted
'70 911T 3.0L "SKIPPY" R-Gruppe #477
'73 914 2.0L SOLD bye bye "lil SMOKEY"
"Silence is Golden, but duct tape is SILVER.”
other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L
gprsh924's Avatar
The cassette deck to ipod hookup will likely be much more reliable from an interference standpoint and have a cleaner sound than the FM transmitter. I use one in the 525 and it outperforms my FM tuner that I use in cars with only cd players significantly.
However, it will still fall well short of the sound quality of a newer head unit with a direct connection. The sound quality is simply better when it is transmitted through the dock connector as opposed to the headphone jack. I like the cassette deck though as a cheap solution.
Garrett
Living and Thriving
Old 04-02-2009, 04:17 PM
entertaining the idea
UconnTim97's Avatar
It should work better than the FM transmitter. The only problem I had with the one I used years ago (portable CD player velcroed to the dash of my Dodge Omni) was that the cassette made a lot of noise at times. I imagine they should have fixed that problem by now.
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 04-02-2009, 04:32 PM
Don Plumley's Avatar
In a pinch, the cassette adapter works well enough and better than the FM transmitter.
The Alpine might have either an RCA (for a CD Changer) or M-Bus connector. If so, you can get a cheap cable from www.ipodcarparts.com/
I just installed the DICE interface - great for factory radios for late 90's to current cars. Works amazing.
Don Plumley
M235i
Old 04-02-2009, 04:45 PM
AutoBahned
RWebb's Avatar
Alpine says it does not have the ability to switch from the radio to an ipod or aux input except in softwarfe - their cd player unit sends a signal to the head unit but other things cannot.
Old 04-02-2009, 04:48 PM
drunk and stupid
HHI944's Avatar
I use one of the tape deck adaptors in my jag with my iPhone, works great and it was $4 at walmart.
Old 04-02-2009, 05:18 PM
DavidI's Avatar
I use a cassette adapter and it works fine. The only drawback is that the ipod battery dissipates. If this is not an issue and you can recharge the ipod, the $5 adapter is perfect.
99 996 C4
11 Panamera 4S
83 SC Targa converted to a 964 cab (sold)
67 912 (sold)
58 Karmann Ghia choptop (traded for the 912)
Old 04-02-2009, 06:46 PM
gprsh924's Avatar
Really, you get less battery life out of the cassette adapter? I have not noticed a difference between the cassette and the headphones; I am still able to manage about 6-8 hours of battery from a 4 year old iPod. However, when I use the iTrip (fm transmitter), I fall to 3-5 hours of battery life.
Garrett
Living and Thriving
Old 04-02-2009, 07:22 PM
Slackerous Maximus
HardDrive's Avatar
I used a tape deck adapter in my 911, and it worked fine. Had to get the volumes and EQ sorted out, but that was painless. Why futz around with the vagaries of an FM signal?
2014 Cayman S, PDK
Old 04-02-2009, 08:11 PM
JavaBrewer's Avatar
I used a iPod tape adapter in my wife's '03 Land Rover. I lasted about 2 hours before I tossed it out the window somewhere East of Victorville on EB I-15. Feel free to pick it up and give it try...
Old 04-02-2009, 09:34 PM
Arizona_928's Avatar
ohh that's what that is...
can't you hard wire a adapter for an ipod?
dolor et pavor
Copyright
Old 04-02-2009, 09:38 PM
Bye, Bye.
Scooter's Avatar
I used the cassette adapter in my '95 993 just fine. I still have it...the adapter, not the '95.
Randy, you want it...then its yours my friend. PM me your contact info.
Elvis has left the building.
Old 04-02-2009, 09:53 PM
How do you do that? Anyone? What would you attach to?
I have an ipod plug attached to the kick panel but the single wire just dead-ends up behind the radio.
Old 04-03-2009, 02:16 PM
AutoBahned
RWebb's Avatar
Originally Posted by scooter View Post
i used the cassette adapter in my '95 993 just fine. I still have it...the adapter, not the '95.
randy, you want it...then its yours my friend. Pm me your contact info.
will do!
Old 04-03-2009, 02:28 PM
Wickd89's Avatar
I have a Alpine CD stereo with a ipod interface via a cable.
Something similar to this:
http://cgi.ebay.com/ebaymotors/ALPINE-CDA-9835-and-KCA-420i-car-stereo-with-CD-XM-iPOD_W0QQcmdZViewItemQQ_trkparmsZ72Q3a570Q7c66Q3a2 Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318Q7c301Q3a0Q7c293Q3 a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem 140311530557QQitemZ140311530557QQptZCarQ5fAudioQ5f InQ5fDashQ5fReceivers
Luis "once was - Wickd89"
Carrera 3.2 - "Faster, Stronger, Better"
-- 2008 Toyota Camry SE V6 (mine)
-- 2005 Toyota Sienna (hers)
-- 1989 911 Carrera Cabriolet -SOLD
Old 04-03-2009, 07:41 PM
Model Citizen
herr_oberst's Avatar
Randy - I know from your posts that you hardly have a tin ear. I'm glad you will be getting a freebie, because you will probably find that the cassette adapter is just OK. (that was my experience, for the one I use in my DD, a toyota pickup)
(I mostly listen to NPR in town, I only use the ipod when I am out of radio range, so charge that baby up before you go!)
I put the Alpine EZ500 head unit in my 911 with an dedicated Alpine ipod adapter and it is a little better, the interface is nice, but lets face it, it's an ipod. In a Carrera. 'nuff said.
Old 04-03-2009, 08:01 PM
If your head unit has RCA inputs, you can use this type of iPod adapter cable. The charger interface connector at the bottom of the iPod produces a cleaner signal than the headphone output jack. This adapter also has a separate circuit to power/recharge the iPod battery.
http://cgi.ebay.com/ebaymotors/NEW-IPOD-TO-RCA-ADAPTOR-ADAPTER-CAR-RADIO-CABLE-PLUG_W0QQitemZ370170481394QQcmdZViewItemQQptZCar_A udio_Video?hash=item370170481394&_trksid=p4506.c0.m245&_trkparms=72%3A1171|65%3A12|39%3A1|240%3A1318
Sherwood
Old 04-04-2009, 12:27 AM
UconnTim97's Avatar
I have a similar set up in my 944. I routed the iPod cable through the glove compartment. The Alpine HU has the controls for the iPod, so I just leave the iPod in the glove compartment. It even charges the iPod while it is hooked up.
Old 04-04-2009, 04:25 PM
