BlueSideUp's Avatar
Send a message via AIM to BlueSideUp
Can the offset of a 1 piece wheel be changed safely?
A friend of mine has some Team Dynamics wheels sitting in the garage. The fronts are a +40mm offset and the rears are +18mm. They are all 15x7s but I need to have all four at +40mm. Can a machinist take out 22mm of offset without causing structural issues?
These are from his track car and will be used on my daily driver.
-Jess
Old 04-21-2009, 10:49 PM
IROC's Avatar
It's impossible to tell without knowing more about the wheel, but I seriously doubt it. 22mm is alot of material.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 04-22-2009, 04:26 AM
T77911S's Avatar
try this guy
http://www.trudesignwheel.net/
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 04-22-2009, 11:47 AM
David's Avatar
How much metal do you have between the bottom of the lug nut taper or ball fit and the back side of the well? As long as you have about 1/8" thickness at the ID of the stud hole after machining, you should be fine.
Old 04-22-2009, 05:23 PM
Originally Posted by T77911S View Post
+1000, I've been very happy with Jim's work..
Old 04-22-2009, 05:50 PM
